Derian house toy run - 9th december
Moderators: AMCQ46, geodude
BrianC
Post by BrianC »
Can i just point out to all Lancashire members, and maybe beyond, about the above event.
Derian house is a childrens hospice on Chorley and does absolutely amazing work for children with terminal or life limiting conditions.
As a new grandad this event has an even more strong resonance with me thos year.
The ride will start from rivington barn a 1pm and it is requested that wrapped presents or even donations would be welcomed.
Come on stormers - lets have a turnout.
More info on the event can be found on facebook - ' derian house christmas toy run'
Or drop me a line
Ps ive just changed chain and sprockets on my storm as well as doing a full fluid change !!!
TaxiDriver
Re: Derian house toy run - 9th december
Post by TaxiDriver »
Yes Brian and I now have heated grips so should be cushty...... :clap:
BrianC
Post by BrianC »
It will have to the blade - ive hit a real problem with the storm
Cant shift one of the long bolts on the suspension carrier
Need to strip it all down
:evil: :evil:
ChrisC
Post by ChrisC »
Yes Brian, I should be there too, they do an amazing job at Derian house,
cheers chrisc :thumbup:
sending you a P.M
BrianC
Post by BrianC »
Great day out with fellow stormers graham(taxidriver) and chrisc. Also in attendance was my brother in law on the z1000sx.
Sadly i couldnt make it a hat trick of storms and had to use the blade - not a bad sub !!!!
Massive turnout of bikers helping the less fortunate
Tomorrow i tackle that seized bolt on storm 2 !!!!
BrianC
Post by BrianC »
Earlier in this thread i admitted i was struggling to remove a bolt from the lower suspension carrier so as to be able to fit one of the brackets for my bellypan.
I had tried my propane torch but to no avail.
A friend of mine loaned me his mapp gas torch and after a few heating and plus gas cycles, and some action with the impact gun i started to get slight rotation.
I then ground off the bolt head and drove the bolt out - what a job!!!
New bolt on order
Brian
ChrisC
Post by ChrisC »
Brilliant day, good chat, good laugh, good company, good amount of toys and money raised, for a good cause
Thanks Brian for the heads up about the charity ride... :thumbup:
ChrisC
