agentpineapple wrote:
lloydie wrote:Road the fecking ass off it :-)
Ancq46 I thank you
then topped it up with oil....... :lol: :lol: :lol:
500ml :-( it used in 250 mile ish
Also lubed my chain with Carl's recommendation
Nice Coffee :lol:
You can't go wrong for £20 Lloyd. :thumbup:
PRO - Impressive weight reduction achieved by removing surplus lump and innards.
CON - Needs a nearby hill to roll it down to get some speed up.
Wicky wrote:PRO - Impressive weight reduction achieved by removing surplus lump and innards.
:D :D
I thought he might have experimented with Nitrous... To get the most out of his last day of Tax :)
You guys :lol: :lol:
I was terrified to split the cases for fear of things going ping all over the place !
Only one blue washer I have no idea where it came from .
I can't believe how simple these engines are .
I will get the bores measured and if they're within speck after honing -hi comp pistons here I come but if not I will have to save and save for an oversize hi comp set :-)
Blimey lloydie, that was a quick strip down!
AMCQ46 wrote:Blimey lloydie, that was a quick strip down!
thats what happens when ive been around the flying banana ! i just cant slow down :lol:
it only took 1/2 hour
Well done Lloydie. :clap: :clap: :clap: Let the fun begin.
http://www.ebay.co.uk/itm/Imperial-Dial ... 35cb2ccb51
Keep everything boxed, labelled and organised so don't loose track of things. :thumbup:
thanks carl but im getting the pros to do it .
ive been saving the take away pots for a while for this :thumbup:
that blue washer is doing my head in as i cant find where it belongs :Wall:
Post a pic of it up and see if it can be identified. Do you have a rough idea from where it came from.
cybercarl wrote: Do you have a rough idea from where it came from
the engine :( i only noticed it when i split the cases . i will dig it out the bin for a pic :lol:
Furrybiker
Post by Furrybiker »
Rode it like I stole it, which is apt as one of the guys I was riding with is a bike copper.
I was having trouble staying with him on what I thought was a Speed Triple. When we stopped for lunch I found the problem, it was a BMW S1000RR :cool2
Well all this modern stuff looks the same from the rear!
:beer:
Jamie - Fancy bumping into you again this evening! Sorry haven't got in touch about the bimble out & about this week (last week) as the same day I last saw you (Bank Holiday Monday) my mum was admitted into hospital so have been dashing about between Clacton, hospital & work.
Enjoy Wales and say a big "baaah!" to the natives.
:D :D
Stripped front end to check on front wheel binding. Thought it might be wheel buckled as it was 'Ole Red's front wheel. Turned out to be mankey callipers that came with M.La Drooper. So they will be coming off to be replaced with the Black set I had on 'Ole Red.
Took a fork off to change the oil & clean it up.
Do the other one tomorrow & will clean up the header while I'm down there...
Then spray them black.
