My ex was out on it just previously and she has a habit of changing down too soon, which reverses the load on the tensioners, .....an hour later but thankfully only 9 miles from home, and pulling out of a junction onto the motorway, clatter, killed it immediately, autopsy revealed the valve timing was out, .Took CCT apart..the bent end of the spring had broken off, letting the tensioner unwind.
Luckily I had a spare old CCT, so did stopper mod on both cylinders.Reset the timing,
Set tps, it was at 980 ohms, now at 500.
Put tank back on, started, stopped..checked all round, the vacuum pipe and the other small bore one were different lengths, obviously the longer to the furthest away and shortest to nearest....checked..no it was the other way round...!
Started up ok, so valves ok....
I was lucky, if I had been on the motorway it could have resulted in bent valves or worse.
So, don't be like me and say..I'll do it tomorrow..
The CCT mod is basically measuring how far the CCT plunger sticks out while in the engine, and how far it sticks out when retracted, make an 8mm bolt/spacer the difference in size, pop it in, replace CCT, check with a screwdriver you still have some free play, job done, and no worries about exploding engines.
What I did notice was when I checked the tension of the broken spring it was only able to give half the tension of the other unbroken spring, when fully wound up.....
Gave my wallet quite a fright it did!
Off to buy an oil change now, as an apology....
