So I broke down today
piggy1
Post by piggy1 »
Bloody battery died and left me in the butt end of nowhere pushing the beast for 2 miles :cry: got love it
macdee
Re: So I broke down today
Post by macdee »
bad luck piggy
you need to check your rectifier to make sure it wasn't it that did he battery in
do this before you put new battery in bike
piggy1
Post by piggy1 »
macdee wrote:bad luck piggy
I hope not as I have already replaced that with a finned one, it was probably the fact that I hadn't ridden it for a couple months and charged the battery up enough to start it... and then went for a blatt and pulled over for a smoke turned it off and oopsy not enough juice to start it...
get a good quality battery, the big twins take a lot of umph to get em going
finned r/r's have been known to fail as well mate..... :(
piggy1
Post by piggy1 »
Thanks dude, I was thinking of a Motobatt battery... is there an easy way to check the R&R? I only put it on a year ago...
piggy1 wrote:Thanks dude, I was thinking of a Motobatt battery... is there an easy way to check the R&R? I only put it on a year ago...
you'll need a multimeter to check the r/r, have a search thru the workshop section for details, I've used a couple of motobatts, very good batteries, the only thing to be careful of, is not to cross thread the two small bolts for the positive/negative leads, as they are a soft metal.... :(
Sounds like battery - even a maintenance free battery needs care & attention. Trickle charging at least every couple of weeks to keep it topped up. Leaving it to go flat can permanently damage the battery.
Bung a new battery in and run a multimeter over the charging system to rule out any other problem.
piggy1
Post by piggy1 »
Wicky wrote:Sounds like battery - even a maintenance free battery needs care & attention. Trickle charging at least every couple of weeks to keep it topped up. Leaving it to go flat can permanently damage the battery.
I know.... I have been sloppy recently so will keep battery trickling like you say, I really dont want to push it for another 2 miles again it was sweatty stuff
bald_pig
Post by bald_pig »
I picked up a yuasa battery for a very reasonable price a couple of months back off of ebay, that's my preference :)
Saintsman27
Post by Saintsman27 »
Bad luck that , I have a optimate on my VTR just plugged in and connected I have
never had a problem ... good luck :wave: :thumbup:
piggy1
Post by piggy1 »
Ordered a motobatt so [SMIRKING FACE]
thomas111
Post by thomas111 »
piggy1 wrote:Ordered a motobatt so [SMIRKING FACE]
did you have to use vasalen when u got the price or was it reasonable
piggy1
Post by piggy1 »
Just a fingertip of KY as was £45
popkat
Post by popkat »
I've heard people say the motobatt wont fit in the space properly and the cover won't go on. In the battery box there are strips of foam on the under side of the lid and in the bottom of the tray, you need to at least remove the ones from the underside of the lid, maybe from the tray too (can't remember) then the battery will fit, it will be tight and difficult to remove again but it will fit and the lid too..
piggy1
Post by piggy1 »
Oh crap didn't know that, thanks for advice thou I will take it [THUMBS UP SIGN]
