Powerbronze dual headlights?
Are the dual headlights any good? After a better beam spread at night over the stock light.
Re: Powerbronze dual headlights?
Apparently not...even worse IIRC.NZSpokes wrote:Are the dual headlights any good? After a better beam spread at night over the stock light.
+1
As standard I believe they are only 35watt bulbs so as you can probably imagine you can't expect much
Now if they could be modified effectively you could be on to something,
- agentpineapple
I heard they can be easily adapted to throw out a lot of light.....
the varado has twin 55 wt bulbs,ive been wondering if it might be possible to make a back up to mount them into the storm unit
Well the 35w bit is easy sorted. Guess the question is the light able to take the heat of say a 90w bulb?sirch345 wrote:+1
The wiring bit is easy.
Someone seems to think a separate earth helps with this set-up with better bulbs. See link:-
http://www.cb500club.net/t917-powerbron ... headlights
