Acquired a 1999 Firestorm
Evening. Acquired a 1999 Firestorm in need of some TLC. Got it for nothing from a colleague.
Fitted a new battery and it fired straight up. Cleaned the cobwebs and mould/dirt off it today and started making a list of things to do and bits required.
First step I think is to give the engine a service. New coolant and bleed, and a radiator cap as it's missing. Then I'll move onto suspension, brakes, tyres and then cosmetic stuff last.
Owned a few bikes over the years so won't bore you with them all. Last few were GSX-R1000, Tiger 1050 Sport, Speed Triple R, Tiger 1050 Sport again and currently KTM 1290 Adventure.
Live in the south side of Edinburgh. Hoping folk here will be able to help with some info when required!!
Daz
Daz
Re: Acquired a 1999 Firestorm
Nice for a freebie .
Got some work ahead of you
- alanfjones1411
Hello and welcome to the forum.Cant get cheaper than that.
welcome to the forum, looks like you have a bit of work to do, but sounds like you got a bargain.
why has the engine cases turned green
- TaxiDriver
Nice one,plenty of help on here mate.....
It's been sitting in a damp workshop for a few years. All cleaned off though. According to the service book it's done less than 1500 miles since it's okay service. I'll do it all again anyway, but at least it hadn't done to many miles before being laid up.
- freeridenick
Welcome Daz. You'll enjoy your 'Storm I'm sure.
Welcome to the club mate
Well done mate that will give you something to play with.
Enjoy , there is loads here to help you and people who are knowledgeable and helpful should you need if.
You might find it a bit of a drag getting down to Grain though
List so far :
Engine service
Coolant flush/bleed
Possible carb balance/clean
Rear shock doesn't look great
Front fork overhaul
Tyres
Brake pads
Braided hoses
Oil cooler pipe doesn't look great
Full set of fairing bolts
Get wheels blasted and painted
That'll do for now!!
Engine service
Coolant flush/bleed
Front fork overhaul
Tyres
Brake pads
Braided hoses
Add / budget for manual CCTs and think about inspecting shock / swingarm linkage as that gets overlooked till bearings rust & seize.
Have you got the plastic bodywork & mudguard?
Bike Maintenance and Upgrades/Modifications
I've already thought about the CCT's so will probably add that to the list.
Already got the service manual.
Got all the bodywork and lights, except one indicator, but probably going to be track bike anyway.
Welcome aboard
Nice bargain by the sound of it
Good luck in getting the bike back into a serviceable machine,
Nice machine, you will enjoy it..
Will need to get some paddocks stands too. Already have two, but the front one is an under yoke one and I don't have the right pin size. The rear one I have has hooks and the Firestorm swingarm doesn't have anywhere to screw in bobbins!
So another purchase......
Although I'm going to need something else when I take the swingarm out!!
Fun and games!
Fun and games!
