Lloydie's track vtr (miss piggy)
As I've been collecting parts over the last few years now I nearly have enough to build a 2nd bike :-)
Tho this one will be a track day only bike and built from spares I have .
It won't be pretty hence the name miss piggy lol unless I get addicted to it then all the goodies will be put on it and the name will have to change .
My plan for it to begin with is to run a slightly tuned engine in it ie
Hi lift cams/ high comp pistons / a bit of porting and a lightened flywheel also a lidless airbox and my 2-1 exhaust with a titanium can this time :-).
It will only have what's needed fitted to it (less to damage when I fall off it)
I still need body work and wheels and forks but as I hope to fit 08 blade parts to kermit I will have the other for this one or I just may pick up a cheap storms front end I'm still undecided on that one .
This build is going to be a long one for sure a year or two maybe three as when I upgrade the parts on kermit the old ones will be going on this one .so don't expect often updates bit I will try to keep it moving along
So to start off with I started a braced swing arm (thanks Seb for the bits ) I removed the brace from the blade swinger and the calliper slider and also the end bit where the chain adjuster go .
This is where it's at now
I need to get a calliper bracket and a rear spindle then it can go off to the welders in a month .
I'm having bobbins on this one to make it easier when I'm on me own as it won't have a side stand .
Tweety
Re: Lloydie's track vtr (miss piggy)
Post by Tweety »
A side note... For track use, when I'm on my own, I use a cheapo wheel-chock mounted to a length of tube along the ground for stability... Just roll the front wheel in and get off...
Then you can use abba/front+rear stands of your choice, since you have your hands free... Doesn't mean you shouldn't put spools though...
Tweety wrote:A side note... For track use, when I'm on my own, I use a cheapo wheel-chock mounted to a length of tube along the ground for stability... Just roll the front wheel in and get off...
That's a bloody good idea :thumbup:
"Mrs Piggy" you muppet! :D
Swingarm looks sweeeet
Jamie in Colchester wrote:"Mrs Piggy" you muppet! :D
it wont be pink mind lol colour suggestion welcome
Virt
Post by Virt »
lloydie wrote: it wont be pink mind lol colour suggestion welcome
A very pale and light red :wink:
Stick on fur like Thumpers stunt bike.............to match the daft ears
Snot green, black number boards & white wheels?
Oh...
:D
Jamie in Colchester wrote:Snot green, black number boards & white wheels?
Oh...
:D
it wont be anything fancy like that :lol:
http://www.motorcyclefairingsale.com/ho ... green.html
Also at the bottom of the page...
* We can Supply Custom Racing Fairing service to any kinds of motorcycle fairing. we will close the Headlight and the Rear seat of the fairing and Print your own racing number on it, then make you can ride this fairing on the track. And this service is FREE !!
Your Kermit does look great by the way ;)
thanks jamie .
i have a little less bling in mind for the body work .
i have a damaged seat unit and a damaged side fairing already that ive been saving .
im not sure if im going with the full fairing i might just use the sides as rad covers .
and maybe a vfr tank !
Squeal like piggy. :lol:
No point in putting a VFR tank on a track bike. You want smaller not more. Unless you thinking of that for Kemit.
cybercarl wrote:Squeal like piggy. :lol:
a vfr 400 tank . 8)
good luck with the build matey...... :thumbup:
i might have damaged clocks you can have, its pretty much intact, but iirc it doesn't have a working speedo, and you don't need that for a trackbike.
i'd suggest knocking up a light weight rear subframe, you'd be surpised how much weight you'd save. i also have a damaged rhs fairing if you want it, its in very good condition apart from a extra chunks been taken out around the indicator hole, but seen as you'd be blocking them in anyways.... :thumbup:
i'd go for rattle can matte or satin black, with gold wheels, also rattle can jobbies to keep the costs down..... :wink:
hell i might even have a spare rear spindle knocking around.
