a bit of spondoness.
- StormyRob
Re: a bit of spondoness.
Fabio
I think this is the day.
I'll pop down later with a trailer and 200 quid mate
Scrap value now and 200 is generous.
- freeridenick
Same as KermitLeFrog said. Tuck it away out of sight but safe and dry then buy a VFR. I'll likely have one for sale in September
Bicycle is the other solution. They never go wrong and you'd be a proper good climber once your thighs have filled out.
last time i rode a bicycle i broke more bones than id ever done on a motorbike lol..freeridenick wrote: ↑Sat Jun 08, 2019 6:01 pm Same as KermitLeFrog said. Tuck it away out of sight but safe and dry then buy a VFR. I'll likely have one for sale in September
well the dirty deed is done, its broken up now and put into boxes marked, bits, expensive bits and turfed outa me sight..
Sad day indeed
Sorry to hear this news mate. Why break it. Surly it would be better to sell as is. I can't help feeling you are making a rash decision again though and will regret it later. Tuck it away and forget about it or why not face the fact that you are lost with it and take it to a good bike mechanic with diagnostic equipment to test things. I can't help feeling there is something electrical going on a it's intermittent and as far as I'm aware you never have really gone through methodically diagnosing the electrics and instead gone for the old change this and change that method.
iv changed everything on the fooker carl.. and i mean everything from pulse coil to caps and plugs and leads, ecu, rec unit, complete loom even and everything iv taken of it iv then tried on the yellow bike to test it, and every single part has worked on the yellow bike. ... i even went to the hassle of removing the entire electrical system of the yellow bike and planting it on the blue one, complete, down to the plugs and ,it was still the same..VTRDark wrote: ↑Sat Jun 08, 2019 9:13 pm
its also worth more broken in bits then selling a broken bike lol... i will see how i feel in a few days and decide what to do with it. i prob know this bike better than anybody as iv had every nut and bolt in my hand at some stage,, the one winter i dont touch the engine/carbs/electrics is the winter it decides to screw up on me..... i could leave it as a garage queen but thats as much use to me as a chocolate fireguard .
its got that bad this time you couldnt even get the thing to run on a dyno, i managed to get home by pushing it up the street with the tickover turned up in first gear......
incase iv missed anything or iv went blind ,what iv changed over the last say two months.
complete loom
large and small ecu boxes x3
plugs x3
coils leads and caps x3
pulse coil x2
kill switch x2
battery x2
rec unit x3
ingnition switch x2
earth strap x2
nautral switch x2
sidestand x1
fuses and holders
starter cable x2
non electrical
carbs x4. and each set had each combination of jetting fitted
inlet stubs x2
all new vac lines
petrol tank and petcock x3
plus everything that makes a motor run lifted of the yellow bike and set onto it,, also anything removed was also tried on the yellow bike and it didnt effect in in anyway,
that only leaves one thing i havnt changed, the engine??? the reason this bike is different is because of the engine and how it goes.. im not gona go down the route of taking the yellow bikes engine out and end up with two piles of broken bike..
thats a lot of work to have been through in two months for no improvement and a lot of time wasted actually.
oh and 4 or five weeks ago i forgot id a compression test done and it was showing as healthy.
complete loom
plugs x3
pulse coil x2
kill switch x2
battery x2
rec unit x3
ingnition switch x2
earth strap x2
nautral switch x2
sidestand x1
fuses and holders
starter cable x2
non electrical
inlet stubs x2
all new vac lines
All I have left is a sticking valve.
Something to take your mind off leccy problems....
Ahh but you havent mentiond if you checked the 'outside double ended whatchamacallit flange guide dodah valve thingy.' *
With out that how do you expect it to run corocktly.
* Technical term obviously
- alanfjones1411
Don't do anything silly Rob you've spent a lot of time and money on that bike.Put it all away for the time being and enjoy the yellow bike this Summer.There's a long Winter coming and what better time to have another go at it.After all it doesn't have to be finished all at once,relax,chill out,think about it,you will get round to getting it done at some time.Just look at how long Duffy took with his fighter,and now he's more than happy.
Love the last linealanfjones1411 wrote:Don't do anything silly Rob you've spent a lot of time and money on that bike.Put it all away for the time being and enjoy the yellow bike this Summer.There's a long Winter coming and what better time to have another go at it.After all it doesn't have to be finished all at once,relax,chill out,think about it,you will get round to getting it done at some time.Just look at how long Duffy took with his fighter,and now he's more than happy.
Ha Ha,
I laughed when I read that last line.
Fabio,
Like you have been advised,
Sit Back, Relax and enjoy the Yellow one for a while.
The Blue one is special mate .
If you sell it you will regret it.
Cheers from Oz, go for a ride on yeller, always works for me .
Fabio,
South Coast
New South Wales
Australia
New South Wales
Australia
Wise words from Alan I agree, so make sure you take note Robalanfjones1411 wrote: ↑Sun Jun 09, 2019 9:06 am Don't do anything silly Rob you've spent a lot of time and money on that bike.Put it all away for the time being and enjoy the yellow bike this Summer.There's a long Winter coming and what better time to have another go at it.After all it doesn't have to be finished all at once,relax,chill out,think about it,you will get round to getting it done at some time.Just look at how long Duffy took with his fighter,and now he's more than happy.
