Brake Caliper Upgrade
Re: Brake Caliper Upgrade
Due to an extreme rush of blood to the head (bought another bike!) I've got a complete set up for the upgrade i.e. CBR/SP1 front calipers, new SP1 pads and ZX10 radial master cyclinder, all now for sale in the for sale section funnily enough. Need to spend more time finishing my XS650 project
Brakes better, not absolutely amazing but better. Was that pads were turned around and now taking time to bed in again!
Anyway, new pads ordered!!
Griff.
Griff.
Immediate plans:Clean it!
DIidn`t read the whole topic, but let me share my experience.
I got the bike with gsxr750 srad front end and 6 pot tokico calipers, but the OEM MC.
I put 19mm radila MC from cbr, braided lines and Ferodo SinterGrip pads.
Last saturday i did my first trqack day with the vtr and it surprised my with the stopping power the brakes had. I could stop later than newer bikes like K4, k6 and 600RR
However, at the third session i thing the cct failed and i had to put the bike on the trailer back home
But the brakes combo i had works really well.
Make sure you service them 6 pot often
As they are prone to seizing .
Yep, when i changed the pads i noticed that 4 of the 6 pot on every caliper were almost completely seized. But now they are all ok.
I've fitted jonacol's ZX10 master cylinder but don't see why anything would need to be cut?
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
'94 KTM LC4 400e
- carlos1982
i've just purchased some Cbr600 calipers and intend to put them on my storm.
do i need to peplace the standard vtr m/c and lines or is it a direct fit?
cheers
carl
cheers
carl
lines are fine but fit new washers.
It will work with standard Master Cyl, but it is better with the matching master cyl off the 600 with a bigger piston diam to move a bit more fluid to ensure the lever movement is more normal.
one of the tables early in the thread shows the calculations and opinions of what it will be like with std
To follow up on other posts trying to work out which model CBR600 were fitted with these calipers.
This is the list
Honda CBR 600 FX/FY/F1/F2/F3/FS1/FS2/RR3/RR4 models fitted with 2x 34mm and 2x 32mm piston
1999 to 2004
This is the list
1999 to 2004
I can confirm that the VTR master cylinder can't quite handle the SP1 calipers; the lever comes pretty much back to the bar. I thought I'd try my luck to save a few quid, but all I've done is waste a couple of hours bleeding the buggers! SP1 master cylinder on the way.
- Pete.L
SP1/2 master cylinder will transform it.grichards wrote:I can confirm that the VTR master cylinder can't quite handle the SP1 calipers; the lever comes pretty much back to the bar. I thought I'd try my luck to save a few quid, but all I've done is waste a couple of hours bleeding the buggers! SP1 master cylinder on the way.
That's good info grichards, helps to stop someone else make the same mistake
I've got the GSXR 100 6 pistons calipers with the CBR 929 M/C and it works like a charm
I've just fitted CBR600 calipers to my 2005 storm.
Already had braided lines and used original m/cyl with 5.1 brake fluid.
Bled very carefully and the difference is scary good.
All up cost me $80- Oz and I would have to rate this the best mod after my lightened flywheel.
South Coast
New South Wales
Australia
New South Wales
Australia
Bit of an update:
I fitted SP1 calipers and master cylinder a few months back, along with EBC HH pads and Goodridge braided lines. On the road they've been good, and felt like a reasonable improvement over the originals. However I had the bike on track for the first time yesterday (at Cadwell), and they were phenomenal. Tons of power, no fade, and gave me huge confidence under braking. Well worth the upgrade!
