Urgent
- marlbororman
Urgent
I have searched, but to no avail, Has anyone got a pic of which pipes go where on the fuel tank? think ive got a pipe wrong, engine running but got bad fueling, and all its had is the tank off for a couple of weeks. No noises from cam chains or knocking or anything, just popping and struggling for fuel. Its not right somewhere, gunna whip tank off in couple of hours
Re: Urgent
You may have done what I did at the weekend...
Have you got the vaccuum pipe on the drainage hole facing downwards? It needs to go on the thinner outlet, think it faces to the left if you are looking forwards.
Thanks to Chris for sorting this one out for me. Hope it solves your probs too..
James
James
- marlbororman
Re: Urgent
looking at the pics i think thats the problem, will let you know shortly just doing a brew then off comes the tank
defo a fuel starvation problem, it even stalled on tickover
- marlbororman
Re: Urgent
- marlbororman
Re: Urgent
Giddsy wrote:You may have done what I did at the weekend...
James
is there suppose to be a pipe on the downward facin one then ?? coz dont think i have anything to go on it, bike running spot on incase you hadnt guessed
Re: Urgent
Nope, it's only a drain hole.marlbororman wrote:is there suppose to be a pipe on the downward facin one then ??
Rich.
- marlbororman
Re: Urgent
cupasoop wrote:Nope, it's only a drain hole.marlbororman wrote:is there suppose to be a pipe on the downward facin one then ??
No Honda put it there to test us all, and ive failed
On an up too, cam chain tensioners must of been read for changing, the engine is noticably quieter too
Re: Urgent
Ha ha! Glad you got it sorted... Seems to be a common mistake!
- marlbororman
Re: Urgent
Running sweet as a nut, just got in after a quick blast....50 miles covered lol. I put a 3.5m shock spacer in while i had it apart,and also reset the spring to setting 2 and damping to 1/2 turn out, rear end feels sweet, front is planted and the bike tips in and out of corners like on rails
:) rides the best it ever has
really happy lol, couldnt stop grinning. dunno how i used to ride it before with the spring on 5
Re: Urgent
This topic has been moved, to the "Workshop" section,
