Carb pipework routing question
Hi ive just got my hands on a 1998 vtr1000 firestorm cali spec bike in bits just got it together but i cant firgre out where the vac pipes and breathers go as all pipes were off would greatly apreciate if someone has a drawing or some know how as im struggling had her running but as soon as you open the throttle it dies bike has pairs removed and blanked and all the drawings i look at theres a valve in between the carbs i dont have one ? Cheers in advance jon
Re: Carb pipework routing question
I'm a bit late to the party here but the key here is had PAIRS and carb valve. If you have removed the PAIRS then there is a connection on the front carb on the side of the throttle cables that requires blanking off where the PAIRS connected. You will also need to reverse..flip the reed valves over inside the cam covers.
See the following thread for more info on PAIR removal:
https://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=26096
