Wheel bearing details
VTR3545
Post by VTR3545 »
Can any of you helpful folk please tell me the details for the front, rear and sprocket carrier wheel bearings...thanks
Sent from my SM-G930F using Tapatalk
E.Marquez
Re: Wheel bearing details
Post by E.Marquez »
VTR3545 wrote: Fri Aug 25, 2017 4:03 am Can any of you helpful folk please tell me the details for the front, rear and sprocket carrier wheel bearings...thanks
The one in the cush drive is a 6322, the 2 in the wheel are 6204UU
6204UU Ball Bearing
Type: Deep Groove Ball Bearing
Closures: 2 Rubber Seals
Dimensions: 20mm x 47mm x 14mm/Metric
ID (inner diameter)/Bore: 20mm
OD (outer diameter): 47mm
Width/Height/thickness: 14mm
6322 Ball Bearing
Type: Deep groove Ball Bearing
Dimensions: 110mm x 240mm x 50mm/Metric
ID (inner diameter)/Bore: 110mm
OD (outer diameter): 240mm
Width/Height/thickness: 50mm
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
VTR3545
Post by VTR3545 »
Cheers....that helps
