Bike turns but won't start
VTR3545
Post by VTR3545 » Tue Dec 12, 2017 10:37 am
Hi....went to run the bike this morning and starter motor turned over but bike won't start and after approx 10 secs of trying get a loud single knock-clunk from the bike....what could be the cause.
For info bike ran great last time started approx 6 weeks ago.....up on stands and connected to an optimate.....never had any starting issues
Sent from my SM-G930F using Tapatalk
StuartWags
Re: Bike turns but won't start
Post by StuartWags » Tue Dec 12, 2017 10:39 am
i would guess the battery has degraded
Post by lloydie » Tue Dec 12, 2017 10:54 am
Clunk is normal with a week battery .
VTR3545
Post by VTR3545 » Tue Dec 12, 2017 11:33 am
Have just checked battery and was sitting as per honda recommendations for fully charged 13.2volts.......so gave it another go an hey presto started as usual......so just strange or a battery on its way out
Post by Wicky » Tue Dec 12, 2017 11:43 am
Cold/freezing weather starting esp after a long lay up will stress the battery. Charge it back up and turn it over for a second or three - switch off and rest it and then apply choke / no throttle and try again. If you flood it rest it again for 5 minutes to clear.
If you haven't done so already check under the rubber hood on the starter motor and check the terminal for corrosion / grease it up.
Post by lloydie » Tue Dec 12, 2017 5:52 pm
I Always keep the battery in the warm if I’m parking it up for a while .
Cold is a battery killer
