Trouble bleeding clutch
VTR3545
Post by VTR3545 » Thu Mar 08, 2018 7:01 pm
Hi...recently fitted new braided hoses and I can't seem to get clutch bled. I initially primed the system backwards using a syringe and forced the fluid up to the reservoir but there is no resistance at all in the clutch lever so I presume air is trapped somewhere....looking for advice on getting this sorted...cheers
Sent from my SM-G930F using Tapatalk
Cadbury64
Re: Trouble bleeding clutch
Post by Cadbury64 » Thu Mar 08, 2018 7:47 pm
I've had this where the air sits right in the master cylinder piston. You could try just wiggling the lever in and out as this sometimes allows the air bubbles to escape through the bleed port in the master.
1997 VTR1000F, 2009 ST1300
cheekykev
Post by cheekykev » Thu Mar 08, 2018 9:58 pm
I found that if you first revirse bleed and crack the banjo bolt at the top to get rid of the air, then go back to bleeding the normal way but open the bleed valve quite wide open so it passes lots of fluid through worked, just make sure you keep the resivour topped up, and keep pumping and pumping, you might feel like you're getting nowhere, but just stick at it, it will happen eventually.
Like what you do
Do what you like
cheekykev
Like what you do
Do what you like
Post by tony.mon » Thu Mar 08, 2018 10:18 pm
Yep, just keep bleeding and eventually it comes in.
About 20 minutes is usually enough.
VTR3545
Post by VTR3545 » Fri Mar 09, 2018 8:02 am
cheekykev wrote:I found that if you first revirse bleed and crack the banjo bolt at the top to get rid of the air, then go back to bleeding the normal way but open the bleed valve quite wide open so it passes lots of fluid through worked, just make sure you keep the resivour topped up, and keep pumping and pumping, you might feel like you're getting nowhere, but just stick at it, it will happen eventually.
Cheers, I will give that a go when I get back to it.
VTR3545
Post by VTR3545 » Fri Mar 09, 2018 8:03 am
tony.mon wrote:Yep, just keep bleeding and eventually it comes in.
Well best make sure that I have a cuppa with me lol...cheers
cheekykev
Post by cheekykev » Fri Mar 09, 2018 11:11 am
Make sure you open the bleed valve enough so you shift lots of fluid through, if you don't you'll just end up moving the air down and back up again, once again keep an eye on the fluid level.
Yes you will use a lot of fluid, but it's not expensive and will save you a lot of time in the end.
Like what you do
Do what you like
VTR3545
Post by VTR3545 » Fri Mar 16, 2018 10:20 pm
Well left it for a week....air must have risen so it bled nice and easy
Post by tony.mon » Sat Mar 17, 2018 12:34 pm
Good, you have no excuse not to drop by Mac's workshop day in Grain, then.
:clap:
mdb
Post by mdb » Mon Jun 11, 2018 6:37 pm
I clamped the slave cylinder then bled as normal. Worked a treat.
