Regulator / Rectifier Modification
Regulator/Rectifiers
The later Storms appear to have a bigger R/R fitted with cooling fins.
Do these still blow and should be replaced with a Yam one (preventative maintenance....mine is OK at the mo)?
- LotusSevenMan
got the yammy r/r on fired up ok then just cut out. tried it a few times and sometimes it ran others it just died, looks like either the battery went when i had my problems before or theirs a cable from battery earthing and draining power, 1 time it fires ok other time it just clicks like no charge, then it fires up again. had the tester on it and the battery was charging when it run but it suddenly would drop from around 14 volts to 13.7 for no reason, hope ill be sorted soon.
This is a common problem.......when i had my old 400cc superfour i used to come across it a lot in 400greybike forums.......it affects the 400's quite badly.......anyway to cut a long story short.....there is another modification u can do to the stock R/R and its quite simple and i sont see why it shouldnt work on the storm......
All u gotta do is source some ali heatsinks for pc memory like these....
mount them onto your R/R and away you go .... instant heat disipitation which counters the cause of your R/R failing. VeetyR(john'o)
Keep it gutter...Keep it grimey..........one!
See link:- http://www.burniemorgan.com/firestorm/reg_heatsink.htmlalan wrote:Yeah veetyr its been done like this already but with a heatsink fan from a pc.
A closed mouth gathers no foot.
- RedStormV
- Location: West Yorks (Bronte Country) - Home of the Negro Lesbian Cornet Players
- Contact:
Hi,
This post is how I found this site and very grateful I am too!
After 3rd R/R failure and 2nd fried battery (they get upset when you pump just under 18V into them) I was getting desparate to find an alternative.
I'd even contemplated paying approx £50 for one off e-bay and visiting Maplins for some heat sink compound and a heatsink, shaping it to fit R/R and compounding it to the subframe!!!!
Went to Rufforth Saturday before last and spied an R6 R/R, she wanted £15 but took £10 when I told her it was only for an experiment - LOL
Only difference between this mod and mine is that I didn't want to chop my wiring harness, so I made up a patch lead (3"-4") with suitable wire and connectors (soldered rather than crimped of course) to go between the harness plug and the new R/R.
One advantage to this is that you don't have to move the flasher relay.
All is fine at present getting a nice voltage between 14 and 15 V.
Graeme
Graeme
- sparrowlegs
- Contact:
- sparrowlegs
- Contact:
been out into the garage and robbed the R/R off the hubbies Storm..coz he's not using his this week and i need mine....and i got a nice surprise...his bike has the standard R/R on it...but some clever person has put a pc heat sink on the stock item and used compound on the back of it and on the frame.....me thinks who ever had the bike before him must've used this site !!!!!! Previous ovmer of our second storm...we salute you
- Stormin Ben
Redstorm,
Either you've been very unlucky with reg/recs or there's some underlying problem causing them to fail prematurely
Make sure the connection where the reg bolts onto the frame & also the earth strap is really clean and free from muck/ rust etc
If this is dirty it doesnt earth properly and goes tilt
But its not a very good one!
- RedStormV
- Contact:
No Ben,
All earthing was fine.
Anywho, just posted this in reply to another thread thought it might be helpful on here:
You can get R1 or R6 R/R from autojumbles ie Rufforth / Newark for £10-£15 and it's a simple mod to change.
IMO don't put another Honda one on - unreliable, although one with heatsink is going to fair better cos of cooling effect.
Alternatively if your stock one is OK, got to Maplins or RS componenets or similar, buy:
HTH
Graeme.
- Small piece of heatsink (or take one off an old PC processor).
Tube or sachet of heatsink compound (white paste).
Cut the heatsink to fit around the shape of the R/R (metal surround).
Drill two holes through to match the R/R ones.
Blather the base of the heatsink in compound so it fills the void.
Screw assembly back in place.
(PC heatsinks are VERY efficient)
HTH
Graeme.
