Odds and sods for sale or FOC
Moderator: VTRDark
FOC (small charge to cover post) unless indicated. Pics on request.
Renthal std sprocket £15 posted. Looks in great nick with no obvious wear.
Standard oil with lines SOLD. Cooler is in good condition and the lines are pretty clean.
Pair if indicator housings. Just the covers and lenses, no mounting rubbers. One is scratched badly.
Pair of pistons and pins.
2 x Gearboxs complete with selector and forks. £40 posted??
2 x Cranks. Come and take them off me.
Starter driven gear, no sprag clutch.
Two sets of auto CCTs. One should still work once wound back, the other has one good and one fooked. I'm thinking these are best for a conversion. Will split.
Pair of chain adjusters.
Right hand controls - kill and start.
Two std reg/recs
Seat lock barrel and keys. I might have the ignition lock too.
Front sprocket cover. Clean enough.
Plastic engine plate and side bit.
cheekykev
Re: Odds and sods for sale or FOC
Post by cheekykev »
First dabs on the oil cooler and lines please, no need to post, I'm only a few miles away, I'll come and pick them up :thumbup:
Like what you do
Do what you like
Martinz
Post by Martinz »
Interested in the sprocket cover for modifying. Where are you based ?
