Pillion grab handle / bracket
Moderator: VTRDark
Re: Pillion grab handle / bracket
Wicky wrote:
You are riding much too slowly Wicky
Or your passengers are not as fat as mine
Mid cheshire
Too old really!
Too old really!
A big cargo net to stop em falling off...
i have the bracket that fits inside the frame that the grab handle bolts to if thats half your problem sorted?
That may be helpful. I could maybe make something to fit.fabiostar wrote:i have the bracket that fits inside the frame that the grab handle bolts to if thats half your problem sorted?
£'s?
Mid cheshire
Too old really!
Too old really!
the bracket i have fits inside the frame now, its the one that the rack or grabrail bolts down onto.. iv a rack here but the centre part is broken if you had a welder ita be an easy fix you can have the lot for £20 if its any use.Roly wrote:That may be helpful. I could maybe make something to fit.fabiostar wrote:i have the bracket that fits inside the frame that the grab handle bolts to if thats half your problem sorted?
£'s?
Sounds good. What would postage be?fabiostar wrote:the bracket i have fits inside the frame now, its the one that the rack or grabrail bolts down onto.. iv a rack here but the centre part is broken if you had a welder ita be an easy fix you can have the lot for £20 if its any use.Roly wrote:That may be helpful. I could maybe make something to fit.fabiostar wrote:i have the bracket that fits inside the frame that the grab handle bolts to if thats half your problem sorted?
£'s?
Mid cheshire
Too old really!
Too old really!
