Starting a engine after a lay up
Now I'm nearing the day (tomorrow ) when I can try to get me new engine (macs old one) started.
I am little unsure it will start as it's been left dry for many months with no oil in it .
So is there anything other to do in preparation before I press the starter ?
Ckennedy
Re: Starting a engine after a lay up
Post by Ckennedy »
Put a bit of oil in the heads and let it work its way down, turn it a few times by hand and all should be good :thumbup:
Ckennedy wrote:Put a bit of oil in the heads and let it work its way down, turn it a few times by hand and all should be good :thumbup:
+1 and maybe pull the plugs and give each cylinder a shot of WD-40. Though she will smoke a bit after start up if you do this. :thumbup:
Great I will give the wd a go thanks guys :clap:
mattycoops43
Post by mattycoops43 »
Definitely needs to be turned a few times slowly as has been said. did it have no oil in at all?
mattycoops43 wrote:Definitely needs to be turned a few times slowly as has been said. did it have no oil in at all?
Dry as a nuns ........ .
I did turn it over by had when I fitted the mcct and it was a little stiff ! Before and after .
Yeah & what about the engine ???
It last run at about 16.30 on the 28/4/2013...into the back of a Galaxy...then lay on it's side for about 10 to 20 mins poss longer BUT NOT RUNNING !
I assume that it cut out on impact as the ignition was smashed amongst other things... :lol: :lol:
I don't remember much as I was out of it having head-butted said Galaxy, do remember those around me panicking as they thought fuel was leaking out & some helpful bystander was standing there having a fag... :lol: It was prob just coolant from the smashed rad TBH.
Once I got it back from Tony sometime in May IIRC over the next month or so it was stripped down & at some stage all fluids were drained out. In hindsight may be I shouldn't have drained the oil but at the time I was more concerned about not having a pool of oil on the floor.
Anyway if you had pulled your finger out & paid for it quicker it wouldn't have been sitting for so long... :lol: :lol:
Re the restart...wasn't there some advice posted recently about this along the lines of...Oil down the bores, turn over by hand slowly then turn over on the starter but with plugs not in & fuel off....
OH & Lloydie what's happening about the set of crankcase covers that I was supposed to be getting back ?
ah what when was that :?: :?: . i have a set some where :P
I am really surprised you haven't tried lube Lloydie :lol: :lol: :lol:
:Lol: I like to try it dry first :-) .
What covers is it mac I'll have a sort out later for you
Top man :lol:
Good luck with the start up dude :thumbup:
Lloydie, My routine would be, new oil and filter, plugs out and a drop of oil squired into each cylinder (as already said). Then with a good battery (or jump leads from a big one) give the engine a good few spins over on the starter, so that the oil gets pumped around the system. If the oil light goers out when doing that even better. Refit spark plugs and fire her up,
sirch345 wrote:Lloydie, My routine would be, new oil and filter, plugs out and a drop of oil squired into each cylinder (as already said). Then with a good battery (or jump leads from a big one) give the engine a good few spins over on the starter, so that the oil gets pumped around the system. If the oil light goers out when doing that even better. Refit spark plugs and fire her up,
Sounds good to me .
Just pick up an oil filter from halfords
I had to go to 3 to find one .
Plugs are out and I gave a squart of wd then left it . When I get back I will fit the filter and oil and see what happens
Good luck with it Lloydie,
[youtube][/youtube]
It's alive .
Only 2 coolant leaks and the fan ain't kicking in but it sounds very nice :-)
