Damping adjustment
Beef
Damping adjustment
Post by Beef »
Hi all,
Currently out playing on track, bike is loads better with the stiffer springs & 7.5 wt oil.
Quick question, how many turns from hard to sod should it be- I’m getting two turns that’s it?!
Re: Damping adjustment
Ah.
You need to take out the fork top and mount the damper rod further in to the top.
You will see that there is a threaded section and a lock nut, you have too much damper rod length protruding and so it bottoms out too soon.
It's a quick fix, easily done.
Ideally you only work on one leg at a time and build the one you're working on to the same length as the other one.
Beef
Post by Beef »
Ah thanks Tony, is there any way to set up the rod when I have no other fork leg as a guide-should I turn the damper screw all the way in for example?
I don't think I've ever measured one, perhaps someone on here has one laying around they could measure?
But if not, I suggest you just screw your damper rod into the cap maybe 5mm more, and make sure they both have the same length.
That should get you a reasonable amount of adjustment.
Cadbury64
Post by Cadbury64 »
My practice is to screw the adjuster in until the head of the nut is flush with the top of the cap, then screw that into the damper rod until the needle just bottoms out (gently), hold the cap in place then back off the adjuster a turn and tighten the locknut. This will mean that when the adjuster screw is flush with the cap, the needle is fully closed. Nearly all of the damping adjustment effect happens in the first 1 1/2 turns, after that there won't be much change.
Beef
Post by Beef »
Thanks all for the comments - and thanks VTRDark for the PM, I'll let you know how I get on. Oulton park next month :D
