I have a 2005 Firestorm which cranks but will not fire. After returning from a massive trip down to Philip Island (4500 km all up, no problems at all for the entire trip) I parked the bike and left it for two weeks. When I went to start it again, the engine will turn over but won't start. I have got a couple of backfires while doing this but it hasn't run at all. This is an Australian model bike -- not sure if there's any difference between Aus and UK models?
Here's what I've tried:
- 100% sure the kill switch is set to "run"
- Tank is 2/3 full
- Thought I might have flooded it, so left for 20 mins and tried again - no change.
- Disconnected front plug lead, connected it to a spare plug. Spark is fine.
- Removed fuel tank, checked that fuel is coming out. Fixed a kinked drain tube but I can't see how that would have caused the problem, and indeed it still doesn't start
- Bad fuel
- bad plugs
- some other carb problem?
- Is there a trick for removing the tank? My tank assembly does not match the picture I have in my service manual (which is for 98-03), nor the picture in the fiches on the "Workshop knowledgebase" sticky thread. On my bike, the fuel tap is connected to the frame of the bike rather than the tank itself, so when you disconnect the main hose to remove the tank, fuel flows out of that hose unobstructed. I got around this by clamping the hose, but surely there is a more elegant way to do it?
- Is there a way to drain the fuel out of the float bowls without removing the carbs? I was hoping to not have to drain the coolant...
- Once I get fresh fuel in there, how do I prime the float bowls as there is no tap to turn to prime? Just crank it over for a while?
