will this fit my 2000 storm
lumpyv
Post by lumpyv »
hello all. r/r cooked itself this morning :sad2
will this one plug straight in?
http://www.ebay.co.uk/itm/REGULATOR-REC ... f9e&_uhb=1
cheers
Re: will this fit my 2000 storm
Yes but that's probably a cheap chinese copy - Look for a CBR125 one on fleabay
http://www.ebay.co.uk/itm/Honda-CBR125- ... 772wt_1151
It looks like it should, but the only bit that concerns me looking at the pic is where the blank is for a 6th pin there is a plastic bit there. That may have to be cut out for the plug on the VTR to fit straight on. Also the spade pins either side of that seem to be slightly longer.
Get a second opinion first :wink:
CBR125's are a direct replacement, you can pick them up cheap. Or the R1/R6 are very good R/R's but the plug on the VTR will need cutting off and spade connectors put on to fit.
Or if you can afford a slightly more expensive one try and get a MOSFET style R/R. Have a read here, a very helpful thread http://www.superhawkforum.com/forums/kn ... how-25117/
lumpyv
Post by lumpyv »
Wicky wrote:Yes but that's probably a cheap chinese copy - Look for a CBR125 one on fleabay
how come i could,nt see that one? i searched cb 125 first on e bay? if that,s a honda part i,ll buy that one
cheers (and you carl)
lumpyv
Post by lumpyv »
will this one fit the plug on the storm then do you reckon?
Yes the CBR125 R/R is a straight swap :thumbup: What's happened to your current one. Is it over or under charging?
lumpyv
Post by lumpyv »
cheers carl, just wanted to check that out.
in answer to your question i dont know but when i switched off after a 20 mile blast this morning i noticed a smell a bit like gun caps and smoke coming out of the rear cowl!! :sad2 it looks like its just the r/r up the creek ? i may be lucky
so the first step is to get a better replacement then see if the battery is bejazered
cheers mate.
Oops sounds like it has been overcharging and the battery will most likely be fried mate. Hence the cap type smell, that will be the battery acid frying which then warp's and damages the cell plates. Give the wiring a good going over as well. :wink:
lumpyv
Post by lumpyv »
cybercarl wrote:Oops sounds like it has been overcharging and the battery will most likely be fried mate. Hence the cap type smell, that will be the battery acid frying which then warp's and damages the cell plates. Give the wiring a good going over as well. :wink:
great :( i did give it all a look and the only thing that looked out of order was the r/r so fingers crossed. the batteries disconnected now perhaps i will give it a sniff!
lumpyv
Post by lumpyv »
good news!! new 2nd hand R/R turned up this morning and ive popped it on and the old girl fires straight up :) lights, hooter ,indicators and everything else seems ok so i think i have been lucky. no time to put the cowl back on but will do later and have a spin. where can i get the little clips that go in from underneath? they were broken and the screw bit was held in with black tape so they got a bit butchered when i took it to bits. halfrauds i guess?
I would check the charging with a multi-meter just to be on the safe side. It should show between 13.5 and 15.5 volts with the engine running at the battery terminals. Yes Halfords sell those panel clips, well they did the last time I was there :)
Excellent good news :thumbup: Keep an eye on the battery holding charge as well just in case the last R/R killed it.
not sure i like your new avatar carl it keeps looking at me :crazy:
Eye Eye :roll:
That's my real pupil and iris in that eyeball as well. Photographed and superimposed onto a 3D model. I've just had to convert 250 frames to layers for an animated gif file. :lol:
