Hyperpro rear spring.
954luca
Post by 954luca »
Have fitted a Hyperpro prgresive rear spring, as in picture, according to the Hyperpro manual, the tightly coiled springs should be at the top of shock, but with this it looks as though it dont sit quite right, hence why I fitted it with tight coil at bottom.
Has anyone else either fitted a Hyperpro rear spring, or have you got one already fitted to your bike, could you tell me what way round you fitted the spring, Thanks.
http://s1244.photobucket.com/albums/gg5 ... 066413.jpg
954luca
Re: Hyperpro rear spring.
Post by 954luca »
anyone 8O
Dont have a Hyperpro rear spring me self, but do have their fork springs.
If the instructions say tight coils at the top that's the way they should be fitted regardless of how it looks to you. There should be a phone number on the paperwork, give them a ring & ask them, if you have any doubts.
954luca
Post by 954luca »
Thanks for reply, I got the spring from Calsport, called them, they don't have a clue, called H M racing suspension specialists, they say, they fit them with tight coils at bottom. Left scratching my head. Seems to handle ok as it is.
If I was to fit it as per manual, the pre load adjuster would only just be sitting on spring, as they are tapered springs? (about 10mm width difference from top to bottom of spring).
grumpyfrog
Post by grumpyfrog »
Macv, how do you rate their front springs, looking to sort suspension both ends over the winter and seeking feedback on whos used what and recommendations?
Don't hassle me
I'll get there at some time
954luca
Post by 954luca »
grumpyfrog wrote:Macv, how do you rate their front springs, looking to sort suspension both ends over the winter and seeking feedback on whos used what and recommendations?
I recently fitted hyperpro front springs, they are excellent, compared to the rubbish standard springs, no more bottoming out, fork dive etc, well worth the 116 pound cost.
Rob
Post by Rob »
I'm not 100% sure, but I would say it won't matter which way round it goes.
It's a spring, so when you compress it the forces act equally from both ends - even though you are only pushing one end. Hope that makes sense.
'02 VTR1000-FY Yellow.
954luca
Post by 954luca »
Rob wrote:I'm not 100% sure, but I would say it won't matter which way round it goes.
Yes, I get where your coming from, that's my thinking as well. :thumbup:
Rob
Post by Rob »
Did a quick search out of interest and found this thread.
http://www.fz6-forum.com/forum/garage-m ... rings.html
Interesting views - you can decide :thumbup:
954luca
Post by 954luca »
Rob wrote:Did a quick search out of interest and found this thread.
That's interesting, thanks for that Rob.
Very happy with them, deff better than standard but then any of the aftermaket springs will be better than standard. Remember when pricing things up for the fork rebuild to add the cost of seals, dust seals & top & bottom bushes they will all need doing whilst you have the forks in bits. Most of the springs come with fork oil in the kit but check before ordering.
StuartWags
Post by StuartWags »
I brought what i thought was a standard shock a while back. it came with a set of wheels for a extra £20. Anyway under closer inspection it is a standard shock with a heperpro spring on it badly painted yellow (?????). Just fitted it but not ridden it yet .
Anyone else tried one?
954luca
Post by 954luca »
StuartWags wrote:I brought what i thought was a standard shock a while back. it came with a set of wheels for a extra £20. Anyway under closer inspection it is a standard shock with a heperpro spring on it badly painted yellow (?????). Just fitted it but not ridden it yet .
I loved the hyperpro front springs, but when I had the rear hyperpro spring fitted, I did not like it, the back end always felt vague in corners, the standard spring felt better to me.
StuartWags
i have maxton front springs and they seem to work well with the standard rear spring ... i will give it a try and see how it goes. Thanks for the feedback
I'll all depend on how many miles the standard shock has done, and if the spring is weight related to your own body weight, plus setting it with the correct static sag, or as near as you can get it. I ran a Maxton spring on my standard rear shock for many years, it was definitely an improvement over the standard shock spring,
