What are the best types for each of the above?
There seems to be different types on evil gay
Also do you use any exhaust paste on silencer joints?
Gaskets - pipe and silencer
Re: Gaskets - pipe and silencer
OEM crushable hollow copper gaskets for the exhaust manifold. (18291-MM8-880 Inner Diameter: 44.05mm Outer Diameter: 52.05mm Thickness: 2.45mm)
Graphite seals for the link pipes/headers (OEM Honda or pattern).
and fully stainless Mikalor Supra W4 clamps.
Get Honda part no. from Ron Ayers > http://www.ronayersmotorcycles.com/fich ... veh=132082
and slap it it into David Silvers search by part no. > http://www.davidsilverspares.co.uk/part ... rt-number/
Shouldn't need any if assembled correctly.Also do you use any exhaust paste on silencer joints?
Thanks wicky
Where do you get the clamps?
Fleabay or online specialist stainless fittings shopBrianC wrote:Thanks wicky
As the diameter of the header / link pipe interface might differ if you have aftermarket link pipes instead of standard its best use some string to get the approx circumference & calculate the diameter of the clamps you require (or if you have the system off just use a ruler)
Best are the W4s as they are fully stainless, whereas with the cheaper W2s the bolt is galvanized and will eventually perish.
Copy & paste the name into eBay
I'm running standard pipes - not that extreme yet !!!!!
