Genuine honda regulator.
Are these a sorted genuine honda regulator? I'm looking for my 3rd regulator in 3 years! http://www.ebay.co.uk/itm/Genuine-Honda ... 2c9d68c83e
http://lincsrideouts.co.uk
Re: Genuine honda regulator.
Yes but no but yes but no but...
Forget anything with a part number starting SH...
Go for a Mosfet type will have a part number starting FH...
Various ones to choose from, Yamaha, Triumph, BMW.
They will be a bit dearer but are far less likely to go pop.
http://www.ebay.co.uk/sch/i.html?_from= ... r&_sacat=0
Yes they are. I bought one from the same listing, same seller. Genuine part.
It's the revised one with the cooling fins, no issues so far.
Revised in that it now has fins on it, they are still tiny compared to a Yam R1/R6 unit &...littlerestraint wrote:Yes they are. I bought one from the same listing, same seller. Genuine part.
...It's still not a Mosfet type tho so still susceptible to burning out...You pays your money.
yes I've paid the money twice already on cheap ones. does the r1 or r6 plug straight in?
I have a Gsxr srad that has a big regulator and plug seams very similar.
MOSFET Regulator/Rectifiers - The Why & The How > http://www.superhawkforum.com/forums/kn ... how-25117/
Fitting a MOSFET R/R > http://www.vtr1000.org/phpBB3/viewtopic ... 82#p351482
I had a strorm that had a small fitted to a finned RR I think it went to someone who had a LED rear light off me
Dont know if it would help to prevent them frying
No R1/R6 is not a plug & play, different conector blocks. However with a bit of patient's, a very small screw driver or a pick you can unpick the conectors from the Honda block & then push fit on to the Yam R/R...saves choping wires on your loom & having to re crimp them...Diabolus wrote:yes I've paid the money twice already on cheap ones. does the r1 or r6 plug straight in?
I think I'll be going for the cut and rewire...
Can't afford a mosfet at the moment , I have a zx10 r/r on the way. Mabey it's because of the warmer weather a lot of owners are having trouble.
what a state that is inbald_pig wrote:I think I'll be going for the cut and rewire...
Recent Facebook VTR group R/R failure...
it's same pic.
I have just tested my regulator as per this video,[youtube] [/youtube]
mine checks out okay, could it be the stator?
You can visually check it to see if it has blackened windings, when they should be coppery. But first get the battery tested if you're having charging problems and the R/R has tested okay.
