found a fuel screw tool i hope
jezman
Post by jezman »
Found this at a little tool shop in meadowhell shopping centre near us while our lass was dragging me round.... A top little find i hope going to see if it can be used to adjust the fuel screws without stripping all fuel tank off.
Re: found a fuel screw tool i hope
That looks good and you will have no issues with the front carb but the rear will still be a little awkward because of the water cooling hose that runs between the carbs. That tool maybe a little too deep but certainly worth a try. A torch is needed too preferably one that mounts to your head or a rifle torch that can mount to the shaft of the tool so you have both hands free.
jezman
Post by jezman »
yes i know what you mean carl going to have a fiddle at weekend and will let you know if it works or not.
artee
Post by artee »
I have one.
I use an extension bar and 7 mm socket to balance the carbs.
Roger
