Fuel tank hoses
KatanaKid
Re: Fuel tank hoses
Post by KatanaKid »
I managed to find some gumption and installed the new rocker gasket this morning. All up took me a little more than an hour and surprise surprise, NO LEAKS! The old gasket was pretty chewed out from the petrol leaking on to it. I ended up using tiny smears of gasket goo in strategic places on the head where the gasket was trying to slide off when placed, then carefully slipped the rocker cover down over the head and tightened up the four bolts. I got a fright at one point when i thought one of the fat washers that sit under the bolts had fallen in to the cam chain assembly, but found it still sitting in the rocker cover. :?
Maybe swearing will help
