Uninsulated rear light connectors wanted
rollingthunderx2
Post by rollingthunderx2 »
Im after the loom to rear light connectors,the metal blade parts to replace the connectors which are frayed and corroded.
I cant find any as they are right angled and not spade connectors, more like knife blade connectors as in Frankensteins switches.
Re: Uninsulated rear light connectors wanted
rollingthunderx2 wrote: Wed Nov 18, 2020 9:59 am Im after the loom to rear light connectors,the metal blade parts to replace the connectors which are frayed and corroded.
Do you mean the white blocks that fit into the black bulb holders in the rear light ?
They are part of the loom, so you need someone with a scrap loom to cut them off.
Might have some but don't hold your breath...
