Front sprocket bolt
FireSpawn
Front sprocket bolt
Post by FireSpawn »
Before I go and snap the thing off am I right in thinking this is a reverse threaded bolt (clockwise to undo) or have I just dreamed this?
Ta :)
Ians98VTR
Post by Ians98VTR »
just dreaming mate,anti clock to undo,as normal 8O
Wow! bet that can shift
xxxrated
Post by xxxrated »
yes normal way to remove it, i use the airgun in work as its a bugger with a ratchet
alan
sprocket nut
Post by alan »
If you have a breaker bar it will be much easier this is how i did mine incase you havnt got access to airgun
Squiffythewombat
Post by Squiffythewombat »
I agree, im changing mine at the mo and a normal wrench wont do it, you need as others have said at least a t-bar or some kind of air powered tool!
Squiffy_The_Wombat
