If only you could get right then move onto the nextPete.L wrote:Its all about finding the right ballance tempest
You need to set the right amount of preload so the bike will stear properly but still have enough dip left to not bottome out. At the sametime you need to adust the the amount of rebound so the bike doesn't either go down too much and not return fast enough so you dont stick to the road when you brake or too little and it feels like a brick and doesn't stick to the road when you brake because it's boucing across ever little bump and ridge on the tarmac.
See, Simple
Re the bottom out on the preload front, I guess we are just talking about under heavy breaking here?
May sound stupid, but going in a straight line, then break hard, is it obvious when the front end bottoms out?
Currently I have my settings on default/standard.
I did try harder settings (as advised on here) but my eyeballs felt like they were going to be jarred out of their sockets going down bumpy roads. Made the front end VERY hard. so I went back to standard. Not tried any softer yet.
The only thing I've really got to compare it against is my Yammie TDM850.
Tried a test yesterday, went down a road and round 2 corners. One corner at 60 and one further along at 70
On my TDM it felt quite fast and not sure how much faster I'd take it, but then went out of my Storm, and tried the same speeds. Deff not happy. I'd say the storm feels comfortable about 5 or 10mph less round corners than the TDM
It may be the riding position (TDM higher, so seems slower)
Poss wider bars, I dunno. the TDM just feels more planted on the road.
This is what I'd like to sort out.
