Exhaust, tell me why....
NZSpokes
Post by NZSpokes »
My LH muffler is much louder than my RH muffler?
Maybe I need to open up the restriction in the RH pipe to make them the same?
Re: Exhaust, tell me why....
You need to repack it as the left is the main one and the right is the over flow
No don't remove the restriction in the righthand header pipe,
NZSpokes
Post by NZSpokes »
sirch345 wrote:No don't remove the restriction in the righthand header pipe,
Why? Its not a tuned system.
NZSpokes
Post by NZSpokes »
lloydie wrote:You need to repack it as the left is the main one and the right is the over flow
They must be hard on packing, I did it 3 months ago. But she does seem louder than before.
The standard system is a tuned system .
The only mod to do to it is to fit race cans and reduce the welds on the inlets leave the rest be
NZSpokes
Post by NZSpokes »
They seem to disagree here, http://ozfirestorm.proboards.com/thread/1929/mod
Denied Access from the oz forum
gl_s_r
Post by gl_s_r »
If it helps I found this response a good while ago about it all, I found it funny and informative:
> > The restrictor in the standard headers is there to
> > assist the pulsing which
> > helps to scoure the front cylinder and to create a
> > turbulence vacuum thus
> > accelerating the gas speed at that point above certain
> > revs. If this is
> > removed the left hand exhaust can will discharge a
> > greater proportion of the
> > gas emmisions.as did the first Akropovic and Two
> > Brothers full exhausts did,
> > until they were modified, to the detriment of the
> > engine performance. Later
> > full systems were designed to overcome this effect by
> > changes in their
> > length, merge angles, tapers and taper length.
> > Honda, Moriwaki, Akrapovic and others could have
> > saved themselves
> > millions in R&D if they had only listened to some AU
> > guy and cut away the
> > "excess" to improve power output !!!!
does that mean both my akra full system and two brothers full system are pants......... :(
I wonder if lloydie will buy them from me...... :lol: :lol: :lol: :lol:
I think we need a full range of exhaust systems and headers represented at the next Dyno day. then we can see what each one is doing.
on my headers I have just removed the welds at the joint to the heads didn't touch the intersection.
those Remus pipes I have on now are running so well, I think I have filled in the mid range dip as well as having extra at the top end. best set up the bike has had and obviously working well with the inlet trumpets.
and to top it all the fuel consumption is slightly better too............ hence I just need to check on the dyno that it is not too lean :(
agentpineapple wrote:does that mean both my akra full system and two brothers full system are pants......... :(
Yes yes yes
AMCQ46 wrote:I think we need a full range of exhaust systems and headers represented at the next Dyno day. then we can see what each one is doing.
I'll refit my mori for the Dyno as I can't have the banana beating the frog !!
I will add Nitrous oxide
You might as well (just to get there ) :-)
