Yep 4: 7.4 ib
It is only guessing on my part but my thinking is that when you take the extra material out for Rogers spec, the flywheel is now light enough that any imbalance in the basket could start to come into play.gl_s_r wrote: Hence my question on the second page of this thread but think it was a little lost in translation with lots of book talk being thrown about when I wanted an answer like yours and I agree, why stop when they did?
Why do you think there was no need to balance the mori spec but Rogers would need to be? I would assume that the lighter the part the less any imbalance would be a problem?
I don't think it will shake to death at all to be honest, or I would have seen some imbalance on the machine when I done it.. If anything it'll run truer more than it did before. What will be interesting is the characteristic of the bike and if it makes it too severe with the on off throttle situations...cybercarl wrote:Not me. One Guy and a very expensive machine. I shall have it on the bike hopefully in the next couple of weeks. I'm quite willing to be the test pilot. Love to live life on the edge and take risks me. What's the worst that can happen...shake the engine to bits. As mr Mon would say....OK that's upgrade opportunity.![]()
Nor do I to be honest. Interesting point about seeing it on the machine. Where does balancing come into play. Is it from possible runout that knocks them off balance, not that I expect any in the flywheel! or is it the centrifugal forces from the length from attaching to the crank.I don't think it will shake to death at all to be honest
Thats an interesting point.. Run out.. Im sure others working on these have seen it as well.... from the factory, the basket has significant run out when the assembly is mounted and indexed off the hub (the hub with it's tapered hole that mounts to the crank snub)cybercarl wrote:Nor do I to be honest. Interesting point about seeing it on the machine. Where does balancing come into play. Is it from possible runout that knocks them off balance, not that I expect any in the flywheel! or is it the centrifugal forces from the length from attaching to the crank.I don't think it will shake to death at all to be honest
I have a feeling the biggest issues will be the starting and idle speed. At the moment my mixture is very good and the bike will idle at 200rpm if I turn it down, with no fluctuations or cutting out. So now is a good time for me to the flywheel on and test for that.
thanks . we'll give that a go first.8541Hawk wrote:Yes it is off of the diameter.
i had mine lightened by E.Marquez. great work he did and ive been really happy with the new found rev up. i chose his lightest method which is the Roger D. method plus a little more taken off.cybercarl wrote:Inertia and rotating mass!
Markus what's you view on the less mass making the bike harder to start and easier to stall at idle. Everything has it's pro's and cons so it would be good to know what are the cons specifically with the big twins. These are big pistons to move around which requires energy and the rotating mass helps with that.
Jscobey wrote:i had mine lightened by E.Marquez. great work he did and ive been really happy with the new found rev up. i chose his lightest method which is the Roger D. method plus a little more taken off.cybercarl wrote:Inertia and rotating mass!
i did have a small issue with the bike stalling at idle 2 or 3 times. but my idle was low around 1000RPM so i adjusted it back to stock 1200RPM and no issues since.
cant wait for the track this saturday and be able to report how it feels at track speeds.
I'm whittling down two today .. one for me, and one somewhat less radical for another SH owner.Jscobey wrote:We'll is like to hear some reports on a much further lightened flywheel on how things function. Do you think it will make throttle response ridiculous? Or contribute to stalling or unwanted side affects?
Erik I'm thinking of sending you my old flywheel for lightening to sell it but if I hear some positive reports, I'll have you REALLY lighten it and then I'll swap that one on my bike.
