stripped firestorm pics needed
seb421
Re: stripped firestorm pics needed
Post by seb421 »
scottyhatchi wrote:anyone have any pics they can send me of the front wiring showing where the wires go like in or out the forks etc which way to rought them safely please if want my mobile number to send pics to my phone just inbox me or comment and ill inbox my number thank u
http://www.ebay.co.uk/itm/Honda-VTR1000 ... 1547wt_906
http://www.ebay.co.uk/itm/Haynes-manual ... 500wt_1158
I haven't got any pics but if you are referring to the clock, ignition and controls. It does not really matter how they run to the plugs on the harness at the front of the bracket. As long as you can turn the steering left and right without them pulling or catching.
On mine I think the ignition and clock wires feed through the middle of the forks through the triple clamp and either run up and attach or along the left as you face the bike along the bracket and around to the blocks on the main wiring harness at the front of the fairing bracket. Then the control wires run on the outside of forks and run along whichever side the control is on.
Did you manage to get the main wiring harness run along the left hand side of headstock (there's a metal clip for it to feed through there) and then along the left hand fairing bracket (Plastic cable tie type clips on the bracket) for it to feed through then the white plastic ends sit in the metal clamps on the front of the bracket. :thumbup:
I had my fairing off today so have taken some pics for you. :thumbup:
Note the clip on the side of the headstock/frame and how the main loom runs across the frame up to the front.
This shows where the TPS and rad whires run across to the other side
Hope this help.
scottyhatchi
Post by scottyhatchi »
cybercarl ya an absolute star thank u so much ya been an extreme help thank u
:thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
eezee29
Post by eezee29 »
thanx so much..this will be very helpful indeed
trying very hard to get over the 50 posts hurdle :lol:
I got the fright of my life when I saw a scottyhatchi thread revived :lol:
Same here.
The dim past rehatched.....
