Polishing the exhaust system
Mav617
Re: Polishing the exhaust system
Post by Mav617 »
Like everything else on the Hound (of the Baskervilles, i.e. big, black dog) my headers are corroded to sh1t. Can they be sprayed with any kind of exhaust paint?
lloydie wrote:
seb421 wrote:i cant remember off top of my head what my old OEM down pipe was like but it wasn't a mess lol
the Yoshi front header was a wider pipe tho
Seb the moriwaki pipes lengths are
Front 600mm to the splitter
Rear 560mm to the splitter
So 40mm difference
And 42mm OD pipe for both
To give you a little bit of tease info as I finally got my hands on my new system 8)
I don't have the pipe lengths yet but I can tell you that the pipe coming from the head has a I.D. of 42mm with an O.D. of 45mm that tapers up to an O.D. of 50mm just past the crossover on the front pipe and right after the small 34mm crossover pipe on the rear cylinder. Then it goes up again at the cans for an inlet of 52mm.
Only a couple of pics so far as I just started cleaning but I would say this system has maybe 10K miles on it at most. :thumbup:
oorwullie43
Post by oorwullie43 »
Mav617 wrote:Like everything else on the Hound (of the Baskervilles, i.e. big, black dog) my headers are corroded to sh1t. Can they be sprayed with any kind of exhaust paint?
When I got the black sparkly one a spare header pipe came with it. It had been sprayed black but who ever done it hadn't rubbed it down! It was a mess. I've started the cleaning with emery paper to start with, it's a bit of work but they will come back to a shiney condition! :?
It's ideal to have the tapers both ends. That should smooth out the pressure differentials. :thumbup:
jonjonsocal
Post by jonjonsocal »
So 40mm difference
Looks like soak citys water ride.. :lol:
http://101thingstodosw.com/orangecounty ... k-city-oc/
Sent from my SPH-D710 using Tapatalk
02 VTR1000f Red
Akrapovic :erection:
Mav617
Post by Mav617 »
Elbow grease I guess it has to be lol
flynavyj
Post by flynavyj »
how quick does it brown again once it's mounted back on the bike? Can you even protect it?
flynavyj wrote:how quick does it brown again once it's mounted back on the bike? Can you even protect it?
they will brown up fairly quickly if you ride in the wet.... :thumbdown:
but once they're done its easy to give them a quick clean every now and then... :thumbup:
Have a look here:-
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=7027
