Replacment side stand
Re: Replacment side stand
cbr1000rr sidestand is supposed to be a straight swap aswell, i missed one on ebay the other day because i was out and it went for £10 delivered 8O
darrenmartin
Post by darrenmartin »
Hey ya snooze ya looze! :wink:
Like Riding Thunder and Lightning
Snoogle wrote:If it is a problem, the simple solution is to do what every other self respecting Storm owner is doing at the minute...converting to single sided exhaust systems :wink:
+1 lol
Griff1977
Post by Griff1977 »
I bought a CBR1000R on an '09 side stand a couple of weeks ago, just delivered Weds, and it doesn't straight swap. On first inspection it looks the part - a nice 15 mm id say longer, but when I took off the old stand, two things (important) stood out -
1. The inner hole was twice the size as old, so it would be loose and only be held by outer hole.
2. There are no 'nobbles' where it contacts the side stand switch.
I can only guess that the later one was changed..... I will keep searching as I've gone for 4mm spacer and would like the longer stand!!
Ill put this on ebay later I think - only paid £4 +£3.50 del anyway!!
Darren, for yours, do you know what year CBR1100 it came off?
Griff
Immediate plans:Clean it!
No it wont as it's only the early models where the stand fits. You will also notice that they are more expensive on the bay as well. About £30 ish :thumbup:
Griff1977
Post by Griff1977 »
Cheers Carl - thought id have a go as it was going cheap, oh well, ill punt for an earlier one! Ta, Griff
CBR1000RR 04-07. You need to change only the side stick. Sensor and bracket held in place. :thumbup:
Griff1977
Post by Griff1977 »
Just ordered a CBR1000RR side stand from Pitstops/A1 Bike barkers, £25 delivered - they have a few he says; 01773 512355 if anyone interested? Griff
darrenmartin
Hey Griff soz for delay but my home pc is playing up.....the side stand i got was off of a 2000 CB1100 (x11) and it was only £22 inc p and p. Hope this helps ya m8. :thumbup:
darrenmartin
Oh and Griff i didnt use the main bracket that it came with (has holes for 2 largish bolts) as only one of the holes lined up. However once id taken this off the stand it was a direct replacement and the side stand switch locating pin just slotted straight in. If your still avin prob's ill switch em back and post some detailed photos. :wink:
Griff1977
Post by Griff1977 »
New side stand fitted- more upright than original! Using 4mm spacer so 'room for growth' when I put the full 6mm in! Pre & post pics to follow!
The only problem with this mod is if you have a rear tyre puncture.
The tyre goes down, and the bike falls over away from the stand.
My Hornet did this three times :cry:
tony.mon wrote:The only problem with this mod is if you have a rear tyre puncture.
good point well made .
So park it next to a bush to slow the fall :-)
marravtr
Post by marravtr »
or park it next to a blue un! :biggrin
Griff1977
Post by Griff1977 »
Pre & post the CBR1000 side stand fitting, spot the difference?
Done!!! Prob go for the full 6mm soon! Griff
