my new/old rear footrest hangers, i had someone machine my old ones into these, not bad if i do say so.......
grumpyfrog
Post by grumpyfrog »
Now, they look nice, :thumbup: any chance of a photo a bit further back so I can see how they set in with your cans? How much of a biatch were they to get modified
Don't hassle me
I'll get there at some time
i'll try and sort out some pictures tomorrow, the bikes at a mates garage being rebuilt, my mate machined them for me, i can ask him if it was hard work or not, if enough people are interested i'll ask him if he wants to offer up a price for doing them for other people, you have to remember there are no rear footrests with this mod tho............ :thumbup:
Opel
Post by Opel »
Adjusted the gear change linkage, details found somewhere, think it may have been the Oz site… and what a mod it is! This really does improve things no end and I can’t believe that has taken me this long to get around to it. :clap:
I also did the 6mm spacer under the top mono-shock mounting and once again I realise now that I should have done it ages ago. :D
Finally, I did the lazy carb clean technique and was most surprised to report that it worked a treat also. It must have cleared out gunk in the pilot jets because my storm is much happier at tick over. 8)
Anyway a good days tinkering… :thumbup:
Fitted a steering damper....had the damper in the shed since my MZ racing days, and decided to fit it rather than flog it. Got a nice 41mm fork leg clamp off e-bay and made the frame mount out of some 3mm stainless plate I had stashed underthe workbench. Very pleased with the result
BigVeeGrin
Post by BigVeeGrin »
starting the long road to restore back to something less corroded - pipes off to replace corroded front studs. Only problem is the pipes wont budge :evil:
Plus took a look at the front sprocket and it needs replacing
Took it out for a last ride of the year
Now it's in hibernation till spring
I will be stripping and cleaning and modding over winter :)
Can't ride but it don't stop me trying
AMCQ46 wrote:Fitted a steering damper....had the damper in the shed since my MZ racing days, and decided to fit it rather than flog it. Got a nice 41mm fork leg clamp off e-bay and made the frame mount out of some 3mm stainless plate I had stashed underthe workbench. Very pleased with the result
you should have said, because i've got a 41mm fork clamp sitting around, it was from a sprint damper. i had to change mine to a 50mm because of the blade forks.
i look forward to seeing what mods you would have done come spring time buddy....... :thumbup:
tattoo
Post by tattoo »
where did you get the can straps from marty??
Snoogle
Post by Snoogle »
Took the cover off to have a blast in some late October sun, realised I had a puncture, put the cover back on.
New tyres needed now! :lol:
Finished me rebuild (see Pimp my ride) :clap:
Went out to scrub me new boots in. :thumbup:
Enjoyed the suspension working as it should! :D
tattoo wrote:where did you get the can straps from marty??
they came with the exhaust mr tattoo, a second hand buy on ebay.......
BigVeeGrin
Still trying to free header studs & corroded starter motor connector nut etc. Joy.
what have you done to your
Today as I have a day off I got off my lazy butt and started to strip the storm for the upcoming service/mod's.
Image Image
The stool come's in handy
Image Image
front end off
Think I need to give it a clean wile I'm here
Head stock bearing's removed ready for taper race's to be fitted
Radiator's removed
Carb's and air box removed
And now just need someone to hold my hand to check clearance's :)
tattoo
Post by tattoo »
moved everything about and dug the winter bike out
i've never had to put a spanner on her except for servicing....not bad for a 93/K reg...17000 miles and only £300 3yrs ago :thumbup:
