bigrich
Re: what have you done to your storm today
Post by bigrich »
yeah i was using hair dryer, watched plenty of vids on how to do it and the stuff itself worked well on the flatter parts, it was when it came to the curves then it would crease and the carbon fibre effect was replaced by a rolled up vinyl effect!
think the stuff would be perfect for putting decals on flat surfaces, or simple wraps but just was not ideal for a whole fairing lower
Honda Britain 50th anniversary storm (26 of 50)
Carbon Hugger
Carbon undertray
Carbon LED indicators
Clear LED rear light
Shark Skinz Bellypan
Harris RearSets
Ohlins Steering Damper
Proflex suspension
Remus high level carbon cans/micron stubbys
i had some spare time today so i dug out some old damaged lowers from a fireblade .
found my 3" grinder and set to work and this is what i got
it still needs losts of work if i want to use it but dont know yet :confused
Looks a bit low, could you shorten the sides and lift it up a bit?
Nice from the front angle, though.
2-3" higher as i said needs losts more work .
i welcome all input on it :thumbup:
I like the improvisation - don't forget to make a hole for the oil level window :thumbup:
replacement sump arrived today thank you tony.mon
a quick wash in the dish washer dont tell the mrs :D
i think it came up really well
just waiting on the replacement headers to arrive then its of the the machine shop to have
the broken exhaust stud removed
Ah, the dishwasher, best friend of the secondhand parts-buyer..... :lol:
Second only to the freezer when installing head bearings.
If I'd known you were going to clean it I'd have sent you the dirtier one.... :twisted:
only clean and fully working parts go back on my bikes bit of a ocd :oops:
Mine had Denso Iridium plugs fitted, fresh 5/30 oil, cleaned K+N filter and re-oiled, stripped clutch and fitted stronger springs, and then went back to Halfords for more oil as I filled the bugger when I hadn't put the drain plug back in........ :oops: £20 worth of new lovely oil in the old stuff.......Bollox.
And 100/80W headlight blue bulb, and a few other bits and pieces while I was there.
Bloody Hell, just heard an Opie Oils advert on the telly while I had Motors TV on. didn't know they advertised on there....
tonyf
Post by tonyf »
Started the SP up, ran fine - hopefully going for a spin upto Welshpool after lunch tomorrow....
tony.mon wrote: I filled the bugger when I hadn't put the drain plug back in........ :oops: £20 worth of new lovely oil in the old stuff.......Bollox.
lol done that before....
done it at work too with a massive compressor but that was like 25l on the floor lol :oops:
thought fkinell, how much oil does this take then seen the slick on the floor!
bigrich
Post by bigrich »
done my oil, rounded off the drainage bolt so had to borrow a rather good socket that cuts into the rounded bolt and hey presto off in seconds!
then replaced it with a nice new shiny bolt and washer BEFORE i but the oil in :clap:
got a rectifier coming off ebay -thanks for the link benny!
put on fairing lowers after them being sprayed black again.
Then i think im pretty much all done for the summer!
Carbon Hugger
Carbon undertray
Harris RearSets
Proflex suspension
Karl_h
Post by Karl_h »
Cleaned carbs and put everything back together, running sweetly once again! Attempted CCTs but came unstuck on the cheese like bolts. Going to get local engineers to weld a socket on and see if they can machine a set out of something more substatial!
back end off for new shocker :wink:
next off is the exhaust, getting it sandblasted later & coated in ceramic stuff.
was going to powder coat the subframe, swinger & wheels but dunno yet, got so much on atm with the scooter run etc... picking a ped up tonight & garage is rammed atm so best get cracking.
not rushing the firestorm though, still got the zxr to ride
*edit----- just bought yet another one lol so there will be 5 bikes in the garage!!! not told mrs yet :angel:
alec
Post by alec »
Started it, cleaned it, looked at the weather outside and decided to clean it some more, cant believe that changing cct's made such a difference to the starting though.
