Starting Problems
robvtr
Starting Problems
Post by robvtr »
Hi all,
long time no post
I'm having problems starting my firestorm
Basically it is turning over but wont kick off, battery is fine.
Last time I went out was xmas eve and prior to that it had been a bit difficult to start but would eventually get going, I'm thinking it may be fuel related but thought I'd ask what may be the first things to check
Rob
stormingjoe
Post by stormingjoe »
check your choke operation
fishface
Post by fishface »
to start mine id
twist throttle a couple of times
press starter let it try a couple of times
then
half pull out choke no throttle
press starter and bingo it would fire up
:wink:
Check the big starter cable running from the solenoid under the seat surround plastic to the starter motor.
Where it terminates in a washer-like connection which bolts on to the starter motor, the cable rots due to salt etc and can't carry the current.
It'll turn over, but slower than normal, and not quite enough to fire.
There's been some threads before on this- worth a search.
Stratman
Post by Stratman »
Don't use any choke, turn her over a couple of times. Then turn her over whilst pulling out the choke bit by bit till she fires.
Otherwise quite easy to flood then its a real mare
robvtr
Post by robvtr »
Thanks fot the replies folks
It aint the battery as it's brand new, plus,
I put the battry off my r1 (that fires up ok) and it still would not go, nearly, but no
I shall have a look at all the suggestions made
Rob
gilson
Post by gilson »
It takes more amps to turn two pint sized cylinders rather than 4 little 'uns. but that seems not to be the issue.
I start mine full choke from the off, very little throttle, if any.
You haven't been doing any work on it? Tank off at all?
Good luck sir, let us know what you find out.
satanzhand
Post by satanzhand »
Fuel, Air, Spark workout which one/s you don't have and go from there.
robvtr
Post by robvtr »
Ok
Turns out that the new battery my mate got me twas a bit shagged and not putting out quite enough juice to turn the monster over
New battery (again) on couple of strokes and away she goes
Rob
fishface
Post by fishface »
hook it up to an optimate money well spent
robvtr wrote:Ok
Rob
I've said it before and I'm going to say it again :)
IMHO your better off spending that bit extra and buying an OE (original equipment) battery a Yuasa :!:
Cheaper batteries show up their true colours when the winter comes around, plus because a Yuasa lasts longer you actually save money in the long term :!:
gilson
Post by gilson »
Good advice I think. A yuasa is about 45GBP. THere are those oddysey batteries which are 80-90GBP...
Are they worth the extra?
Picked up a cheapie a year or so back, and it's fine.
No Optimate or similar, but I use it pretty much every day, so it never leaks the charge away.
IMO it's how long you leave batteries between cycles that kills them, sulpahting I think it's called.
satanzhand
Yeah I have been told the same thing down in NZ as well... Basically I've been told if you don't ride your bike for about three days your battery is heading for the cemetery, unless you keep it charging all the time.
I admit our climate is very hard on batteries though.
gilson wrote:Good advice I think. A yuasa is about 45GBP. THere are those oddysey batteries which are 80-90GBP...
Where did you see Yuasa batteries for around £45 :?: as that is a very good price. Wemoto is the best price I've come across and that's at £57.50 + delivery.
I've heard about Odssey batteries before, but having a look for an exact price for the Firestorm, they don't seem to list them :!: They obviously are a better battery, but as you say cost a lot more too :!:
satanzhand wrote:Yeah I have been told the same thing down in NZ as well... Basically I've been told if you don't ride your bike for about three days your battery is heading for the cemetery, unless you keep it charging all the time.
I agree with that :!: The battery in my old Suzuki GSThou that was used everyday lasted for 8yrs :!:
