Vacuum hose
Jonesey
Vacuum hose
Post by Jonesey »
anyone know the internal diameter of the vacuum hose between the carb and the petcock????
Cheers!!!
JohnD
Post by JohnD »
I had to find this out a while back to fit a hose joiner in there to aid balancing of the carbs.
I measured it to be 5mm. However when I put a 5mm hose joiner in there, it fitted, but was a touch on the large side... so would reckon it's probably 4.5mm
Hope this helps / makes sense !
cheers
John
Jonesey
vacuum hose
Post by Jonesey »
Yep John, it's actually 4mm. Cheers buddy.
jonesey.
JohnD
Re: vacuum hose
Post by JohnD »
Jonesey wrote:Yep John, it's actually 4mm.
..& i'm a spaz for not being able to measure correctly !! Doh !
Well, according to my set of "professional quality" hole guages from Lidl
it's 3.958mm dia on a new piece of pipe, but surprisingly, when you then measure the end that's already been fitted onto a fitting for a while it's 4.183!!!
But there's no acceptable wear limit quoted in the Haynes Manual, so I have no idea when they'll need replacing.
AND they're not a check item in the service schedule.
So I'm blaming my next accident on vacuum pipe failure.
Let's see what the insurance people make of that :P
