size of nut ???? help
I need to get a socket to fit the swing arm spindle nut ( left side, not bolt end) but not sure of size , 26mm ??? anyone help.
torque
Can't find the size of the nut, kids have moved my cd-rom, but according to the book the torque setting needs to be 93N-m / 69lb-ft when putting back together.
Please check this when removing, I hate you to tighten it too much
t00lkit
t00lkit
Have the manual on the system at work, not sure which one you are on about but here are a few choices !
Rear Axle 18mm
Final Drive Sprocket nut 12mm
Shock Upper mounting 10mm
Shock Lower 10mm
Shock to swing 10mm
Swing arm pivot nut 18mm
Nothing in the "Rear Wheel / Suspension" section bigger than 18mm
If it's none of these send me your mail address and I'll send the page of sizes as an attachment.
Rear Axle 18mm
Shock Lower 10mm
Shock to swing 10mm
RQ.
The Stig of 2 wheels as well as 4 !
I always go abit bigger
but dya have two big rachets/t-bars to hold both ends of the bolt, can't use a spanner. If your taking it off then loosen it before you put the bike on a lifting stand, saves pulling the bike off d stand whilst ya popping blueies out ya arms.
Del. (wots 3mm between friends ehh)
