No, I'm not taking the "P" at all, I genuinely thought your post was very good information for anyone thinking about different calipers for their Firestorm. A while back I was thinking about fitting a pair of GSXR1000 6 pots to my bike but it didn't occur to me to find out how good or bad theygilson wrote:Not sure I understand the above? Am I getting a telling off from the admin?sirch345 wrote: I appreciate you posting that GilsonVery helpful
Cheers,
were first, as you did by doing some research.
However after giving my calipers a good service I'm pretty happy with the standard set-up now
I also thought that was a very good point tooJonesey wrote:The only thing i would add regarding the 6 pots is that with those there is so much braking power, that unless you've had your forks modified to suit them, your front suspension could become overwhelmed under harder braking.
Don't know if this helps at all?
Cheers,
