Rattle
- stormingjoe
- Contact:
Re: Rattle
depends, are carbs balanced?, could be clutch basket? could be primary chain?
Re: Rattle
Depends how loud the rattle is. Mine has always had a slight clutch rattle which goes away when you pull the clutch in, so, yes, its normal unless its really loud
Re: Rattle
Very well put Paul, I'd agree with thatStratman wrote:Depends how loud the rattle is. Mine has always had a slight clutch rattle which goes away when you pull the clutch in, so, yes, its normal unless its really loud
Slightly more so when the engine oil is hot I'd add to that.
