FAO FirestormMike
FAO FirestormMike
Mike, I think you said you painted your tail/seat plastic's on your Firetsorm using Halfords rattle can spray paint (as below). Did you need to lacquer the paint once you'd painted it :?:
Cheers,
Re: FAO FirestormMike
That was quick :)
Thanks for the info and paint link Mike :!:
I thought your seat plastics looked pretty good in the pic, so I was wondering if you had lacquered it for future reference IE. if I see a hugger or belly pan for sale and I need to re-paint it I'd know what to do.
Cheers,
Beamish
Post by Beamish »
Use RS paints for a perfect colour match, I would recommend them but they are pricey. http://motorbikepaint.co.uk/
RedStormV
Location: West Yorks (Bronte Country) - Home of the Negro Lesbian Cornet Players
Post by RedStormV »
At Rufforth last Saturday caught this guy and his lady:
http://www.bikecolours.com/
Touch up kit for Red Storm was £10 - for that you get 3 X 20ml bottles, one of ground coat, one of top coat and one of clear coat (laquer). Oh and a set of instructions.
I thought that was pretty reasonable considering the cost of 1/2 litre of colour matched single coat stuff.
Haven't seen him there before, but at least he has website. Seems to cover the whole spectrum (get it :lol: )
warby221
Post by warby221 »
I’ve used these chaps in the past
colour match was pretty good, fast delivery and not a bad price luckily I’ve found a paint suppler locally that’s sh*t hot at matching so now use them as I prefer the 2k system
http://www.paints4u.com/
Thanks guys to all of you for your input, very much appreciated :D
I'll make a note of those links :!:
Cheers,
Stratman
Post by Stratman »
Spray it Yellow. You know it makes sense :D
Stratman wrote:Spray it Yellow. You know it makes sense :D
:lol: :lol: :lol:
Jim67
Post by Jim67 »
Because no-one would steal it. :lol:
Yeah because only monkies steal bannanas!!! :lol:
Jim.
RACIST!!! not me....I'll race any fooker!!!!
Just finished re-spraying a side panel using the Halfords Y124 shining Pearl Yellow.
Colour match is good, (took two full cans though) and I then lacqured with spray can standard stuff.
The finish is different, maybe I should have flatted it between each coat?
It's not exactly dimpled, but you can see that the original is gloss and my effort seems more of a vinyl finish.
Mind you, never bothered to spray anything before, so maybe I should have left it to the experts.
It'll do for now.
Also my first time of trying to repair cracked plastic using an old soldering iron- that seems more successful, but in hindsight I should have used a bit of body filler and smoothed it before spraying the colour on.
Looks alright from a distance, under the cover, in the dark, if you squint.
baldrocks!
Tony, the earlier Yellow is one of the most difficult colours on the Firestorms to match, so if you got a good result that's excellent :!:
To get a good finish (shine) on the lacquer, once you've given it time to harden off, you'll need to buff it up, either with polish, T cut or a cutting compound, or all three. Be very careful though on non flat surfaces not to rub through to the paint,
Thanks, Chris, will give it a go and report back for others to view.
