DataTool vito Alarm removal
Hi, I have a DataTool vito Alarm which i think is draining my battery after 8 days the battery is totally flat is it a big job to remove?
Re: DataTool vito Alarm removal
Geoff,
You could try using a battery charger/monitor that is specifically meant for a bike, that will keep the battery charged up, would be easier than removing the DataTool Alarm. Plus your bike will still have it's security
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
The alarm should not drain your battery flat in 8 days, if it can't hold more charge than that sounds like it needs replacing.
As suggested, an Optimate is a good investment - particularly if you don't use the bike every day.
Hi Geoff, I have the same alarm on my Storm and it normally takes about 3 weeks for it to drain the battery, so I bought an optimate charger and this solves the problem easy. I just plug it in when I park it up in the garage ![Wink :wink:](./images/smilies/icon_wink.gif)
