tank range
bikerman
tank range
Post by bikerman »
just got my storm and im lovin it, however in the one week that ive owned it, ive had to put fuel in it 3 times! i only used to put fuel in my thunderace once every 2-3 weeks! does the later 19 litre tank fit the early storms??
Stratman
Re: tank range
Post by Stratman »
Welcome to the forum - yes and no is the answer to your question, but try searching as there are loads of losts on the question as it is asked quite often. Depends what sort of mpg you are getting too. I usually manage 110 miles plus per tank, nearer 120 (16l tank)
Don't let her labour in low gears but also don't rev the nuts off all the time (you don't need to with the torque) and you should do similar, IMHO :D
bikerman
Re: tank range
Post by bikerman »
well at the moment my fuel light comes on at around 80 miles, but i am admitedly giving it some stick! how far can u usually go once the light comes on?
Stratman
Re: tank range
Post by Stratman »
Depends how much you can get in after its come on :) . That's not a fatuous answer either. The sensor in the tank is on a piece of wire which can be higher or lower in some tanks, so if it came on at 80 miles and you went another ten before filling up, see how much you get in then just work it out from there.
Usually though, about 20 miles max on reserve
bikerman
Re: tank range
Post by bikerman »
is it common for the light to sometimes come on briefly then go off again as the fuel is moving about?
Stratman
Re: tank range
Post by Stratman »
Yes. Mine does
bikerman
Re: tank range
Post by bikerman »
mines got a k&N and is dynojetted and has some remus cans, would that make it a bit more thirsty?
Seeker 77
Re: tank range
Post by Seeker 77 »
bikerman wrote:mines got a k&N and is dynojetted and has some remus cans, would that make it a bit more thirsty?
The reverse i should have thought???
Jbrebel
Re: tank range
Post by Jbrebel »
Seems to be "topic of the month" at the minute this...:biggrin
Sorry to say this mate, but it's a big LC VTwin...they all tend to be thirsty. The only thing that lets the storm down compared to some similar is the amount of juice you can put in the tank.
If you think the VTR is bad try a Superduke :eek2
SP1's rock!
Beamish
Re: tank range
Post by Beamish »
Yes the old Storms are not frugal in the least, you should get between 80-110 miles to a full tank (that is totally full) otherwise something may not be set up correctly.
