powdercoating wheels
- firestarter1977
hi all
am after some advice , i am looking to get my 6 spokes coated. Bearings are out and i can make caps to plug the bearing areas.
What should i do with the cush drive area and where the thin o ring sits on the rear
also i wondered if i need to cover where the discs sit on the front its a vfr front and the faces are machined finish at the moment.
Cheers mark
Cheers mark
the thunder rolls on!!!
Re: powdercoating wheels
Any good powder coater should mask up and cover the areas you are talking about, i've had my wheels done and the place i used did it all, i just gave them the bare wheels.
cheerz
kev
kev
Check with them first, mine didn't and I had to scrape coating off all the surfaces and re-tap the threads.
Which is why they're not in the recommended section.
- firestarter1977
ah
i have sent them with a friend who is taking them tomorrow , he knows which parts i want leaving .
hopefully they will give me a yes or no tomorrow !
regards mark
regards mark
They should do it for you if there any good!!
Mate has just has his storm wheels done they look the dogs dangleys and for £35 a wheel they are brilliant!!
Adam
Adam
Only a biker knows why a dog sticks his head out of a car window.Â
- firestarter1977
hi pal
they are doing them for me all masked up ect , £40 per wheel
Nice looking storm you got there firestarter ;)
I'm going to have to get something done to my rear wheel - it's got lots of manky spots on the paint from brake fluid as a result of the leaky caliper. Half tempted to DIY paint it though. Would I need to do any prep for powdercoating?
- firestarter1977
thanks mate ! Will look different with the 6 spokes !
All i have done is remove the valve , dust seals , o ring and bearings .
They are masking everything up so should be good to go when they are done .
Regards mark
Regards mark
- firestarter1977
that area should be masked mate .. If its the bit that sticks out near the cush drive with a oring . Will find out soon lol
- firestarter1977
hi matey
the wheels are done , look good !
got the bearing but still need seals and a new front tyre before i fit them , might be a while as the credit crunch takes hold !
will post pics when done fella
regards mark
regards mark
