Re: chain splitter / riveter
I just rivetted it on the bench and fitted it over the swingarm.
You can do this if you remove the LH side footrest.
An angle grinder removes the old one no problem!
stormingjoe
Post by stormingjoe »
if you know of anyone coming this way (basingstoke/heathrow) i got one you could borrow
tony.mon wrote:I just rivetted it on the bench and fitted it over the swingarm.
Remember Tony, Mike is on the SP now, so not so easy as the Firestorm :wink:
warby221
Post by warby221 »
PM sent
Zakalwe
Post by Zakalwe »
I picked one up of eGay for about £30. Not the strongest piece of kit ever, but fine for what I needed. Your welcome to borrow it it you are over near Devils Bridge anytime.
FirestormMike wrote:Sorted, courtesy of Mr Warby. cheers matey.
Yes, Chris is right. The chain is routed through part of the swingarm brace, so it needs to be riveted on-bike.
Oops!
But the angle grinder bit still works, for those of us who spent the money we were saving up for an SP-2 with on angle grinders. :oops:
