Re: Carb cleaning..
Phil-VTwin
Re: Carb cleaning..
Post by Phil-VTwin »
Yes it does work helped along with a old toothbrush.
If you find jet holes blocked like it did on mine and cant clear them with wire, get a blow touch and heat the brass jets up until they turn orange then let them cool down.
Ride Safe
Phil
Re: Carb cleaning..
Was warned off about using wire to unblock jets as it can increase the bore, but i recon if you use something softer than the jet its self, like thin copper strands out of low voltage wire [like speaker cable], it should be OK.
I have also used the blow trch method and it works
warby221
Re: Carb cleaning..
Post by warby221 »
Paint stripers a good un to mike if the fuels varnished on the carb’s just make sure to take all the plastic bits off paint on the striper and leave them in a sealed bag overnight
Seven Of Nine Firestorm
Re: Carb cleaning..
Post by Seven Of Nine Firestorm »
Give the jets / parts etc a good blast of air through a compressor and everything else after its been soaked and washed also before, it does help get some stuborn bits out.
stormingjoe
Re: Carb cleaning..
Post by stormingjoe »
ultra-sonic cleaner, jewellers use, them are the best way to clean them up doesnt damage nowt.Like thishttp://www.ultrasonic-clean.co.uk/
Re: Carb cleaning..
Needle jets might be worn anyway, some carbs are worse than others for this, so why not just buy replacements? They're only a few pounds each.
warby221
Re: Carb cleaning..
Post by warby221 »
FirestormMike wrote: Fitted new battery, thumbed the starter and ................ nothing.
Next job is to find out why the starter doesn't spin over. When I press the starter button, the petrol and oil warning lights come on .
Sounds like a short some were or possible power back feeding though the earth
Bridge the solenoid and see if it turns over on the starter
warby221
Re: Carb cleaning..
Post by warby221 »
FirestormMike wrote:Job for tomorrow then.
Had enough now as I stink of old petrol and thinners.
No change there then he he :lol: :lol: :lol: :lol:
Sorry m8 couldn’t resist
Jbrebel
Re: Carb cleaning..
Post by Jbrebel »
:silent:
:lol: Oh well Mike, at least you have it sorted!
SP1's rock!
Re: Carb cleaning..
put the stand up.....
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :lol:
Makes left-handers easier, too.
