He makes it look easy.
- bikerpiker
This chap makes it look so easy, have any of you guys tried turning your bike using this method ? It deffinately has it's benefits ,but i personally don't like the idea of all that weight being taken by the sidestand/bracket .
CLICKY -
CLICKY -
Stevie
- Phil-VTwin
Re: He makes it look easy.
I see too much flex in mine when it gets leaned over so i dont think it would last that long but a good way of turning it round
Ride Safe
Phil
Phil
That trick would be much more use if there was some way turn end up with the bike facing the opposite direction...
- bikerpiker
My local bike mot place used to actually balance my Triumph Daytona like that when doing mot checks ,as the centre-stand had been removed.
I hated the idea so much that i made a stand which bolted onto the bracket where the centre-stand had been removed,and i would take the stand to the mot garage with me.
Must say though ,it does seem quite a common way to move your bike in a confined space,judging by the youtube vids.
Stevie
I do it all the time on the Fireblade. No worse than sitting on the bike with the stand down.
dead easy mate, got me out a few tight spots in the past
- bikerpiker
Tbh the real reason i made the stand for the Daytona was for maintanance at home,but it did come in handy for mot's,as the Triumph was so heavy it took two mechanics to balance it on the side-stand ,or maybe they didnt have the nack.
I've just checked this 'site Mike posted a while back ---------------
CLICKY- http://motoprofi.com/motospecspictures/ ... -2002.html
every make and model of bike is listed, how accurate these figures are, i'm not sure, but it's saying .....
Firestorm dry weight- 192kg/423lbs
Bandit 1200s (2002) - 220kg/485lbs
Daytona 1000 (1991)- 268kgs/591lbs ,.......so my Daytona1000 was 12 stone
heavier than my Firestorm ,and 7.5 stone heavier than my current Bandit 1200s
It might very well be easy enough to turn a sports bike like that, but it's possibly different on an old dinosaur like a Triumph Daytona , i dare say it's all in the knack ,and being confident ....ffs...ive only just mastered getting the bandit on it's centre-stand
Stevie
- LotusSevenMan
Blimey! That does look easy, but I know what would happen if I tried it. The stand would sink into some loose ground and I'd either a) not be able to shift it at all or I'd be laying on my back 'cos I'm pinned down by the bike!!!
- Phil-VTwin
Don't think the sidestand would snap, I've developed the trick of leaning over the bike from the left hand side, reaching down to the RH pillion peg, lifting the rear wheel off the ground and spinning the rear wheel when cleaning chain lube off the rear. Just the sidestand and front wheel on the ground.
Also pulling the bike to the left so that the front wheel can go round with a kick of the tyre for the same job at the front. this time, just the sidestand and rear wheel touching down.
Sidestand seems plenty strong enough, although I wouldn't try it on anything other than a good surface.
BTW, you can also lean a bike with a centrestand over so that only one leg of the centrestand is in contact with the ground and do the same thing.
- Phil-VTwin
Thats good to know, there seems to be a far amount of play on mine at the pivot bolt but i dont know if this is normal or not
Ride Safe
Phil
Phil
Dont try it on tarmac!!!!
Jim.
Jim.
- Pete.L
I wouldn't recommend it.
That's almost exactly how I bent my stand on the Storm.
I was off touring, seeing some family North of Newcastle. Admittedly I had a couple of bags loaded on the rear seat with all my kit in them. All I did was lean the bike over on the side stand and front wheel, lift the rear off the ground, and start spraying some oil on the chain. Next thing I new the wheel was back on the floor and the bike was trying to squash me
It was fixable, with the help of a vice and a big hammer, but I wont be recommending it on my 'Safe biking practices list'
I can't say I ever had an issue-but i don't do it all that often. Only if I HAVE to wiggle the bike out of a tight spot. If they were supposed to be moved like that it'd be common practice all over I suppose
Get it wrong and they go with a fair old bang
have witnessed that more than once...
SP1's rock!
