wat air filter?
bluelou
wat air filter?
Post by bluelou »
hello and thank you all for your advice :wave: wat do you reckon is the best air filter 2 go for :confused standard,k and n, or pipercross? currently bike standard i have a dynojet kit to fit , have been running it on art racecans which may b noisy but giving me better mpg , with no ill effects, standard cans r back on bike for the mot but id like to fit the dynojet kit n race cans,im not sure wat filter would provide best reasults :confused .dynojet seem to sugest standard filter but i just not 2 sure wat set up would work best :problem: :problem: :problem:
coledog
Re: wat air filter?
Post by coledog »
I like K&N, But others may have more tech. advice.
Matt Black 04 model
Razor
Re: wat air filter?
Post by Razor »
I've allways used K&N filters, not sure if they're any better than other makes.
One reason I don't put standard air filters on is that K&N might a bit more expensive but they're reusable, give 'em a wash re-oil and chuck them back in, saves money in the long run.
Growing old is inevitable. Growing up is optional.
Jbrebel
Re: wat air filter?
Post by Jbrebel »
I ran a K&N in mine but I've heard loads stick with standard air filters.
K&N's can create an airbox "cough" or make an on going one worse-more so at low rpm.
SP1's rock!
bluelou
Re: wat air filter?
Post by bluelou »
will a k&n have a negative effect on a standard setup , currently she been a royal pain in the butt :mad2 :mad2 :mad2 replaced battery, plugs ,stripped carbs.checked regulator and charging circuit all spot on . totaly convinced air filter to blame , i got art race cans and a dynojet kit to fit, but she standard at the moment as waitin to sort mot out ,
Re: wat air filter?
Check by leaving air filter out, and give it a quick run down the road.
Engine won't ingest much dust etc on a half-mile run to check it.
Put the airbox top back on, though.
You should be able to notice an immediate difference if you're right about the filter.
bluelou
Re: wat air filter?
Post by bluelou »
your quite right m8, no filter n she startin n runnin well just got to sort new filter,get a mot n im back on the road :thumbup: :thumbup:
