My bike is sadly (because I'm under 21) restricted to 33bhp...
Its not too bad though....just no power past 6.5k rpm :S
It runs nicely between 4k rpm and 7k rpm at which point the restrictors really kick in...
Now, the problem is, under 4k rpm :S
If the bike has been kept between 4 and 7 k rpm I can drop the revs down to almost idle, and if I dont keep it under the 4k mark, it will accelerate nicely again...
However, if I am cruising through a 30 or 40mph speed limit area, I keep the revs between 2.5 and 4k rpm...
When I then open the throttle the engine struggles to rev...and stutters and jolts...
And then its all fine again over 4k rpm
It also smells rich at times when the revs are low...
Anyone had a similar problem?
Or anyone else had a 33bhp restricted Firestorm?
I wondered if the choke was sticking on (isnt it actually an enricher on these bikes?)
Either that, or a bit of dirt in the carb...
Might have to whip the carbs off and clean them...
Any ideas?
